Old 12-24-2004, 02:34 AM
primera man's Avatar
"P-Man"
Main glue you use??
As the question says...what glue do most of you use.
I've always used Tamiya glue as I've find it great apart from the big bloody brush they stick in the bottle.
Today I was given a bottle of the Revell glue pictured below to try out.
I must say it was nice and easy to use with the needle, but IMO i found it to be very disappointing with the drying time and the length of time to "hold" a part together before you could let it go without it falling apart.
So it got drained out and refilled with my Tamiya cement.....thankyou Revell, at last you have made something i can be happy about!!
View All My Models Here.
Old 12-24-2004, 02:59 AM
LMGTR's Avatar
LMGTR LMGTR is offline
Re: Main glue you use??
I use the Humbrol liquid cement with the needle applicator. I stay away from Testors stuff yuck.
Old 12-24-2004, 03:05 AM
sjelic's Avatar
sjelic sjelic is offline
I use this Revell on the picture as main one, next one is Tamiya extra thin cement and for some big surfices Tamiya regular cement.
For the end for resin/metal super glue (thicker) and paper invisiable glue for clear parts.
Sasa Jelic
SCALEMAKERS
Old 12-24-2004, 03:13 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I use Tamiya Extra Thin Cement, Tamiya CA Cement Quick Type and
Plastic Weld.
Steve a.k.a. Hiroboy
Old 12-24-2004, 03:16 AM
rapstagangsta's Avatar
rapstagangsta rapstagangsta is offline
I use Humbrol Precision Poly Cement
Old 12-24-2004, 03:19 AM
Lownslow's Avatar
Lownslow Lownslow is offline
i use M.E.K. works pretty good makes a nice strong joint. and a quart of it can build about 50 cars for around 2 dollars
Old 12-24-2004, 03:32 AM
Jay! Jay! is offline
Horizontally Opposed
Tamiya Extra Thin Cement. Revell "kite" thingy thin plastic cement as a backup.
Zap-A-Gap CA Cement thin and gel plus the every-store-brand CA kicker.
Elmers or Krystal Klear or Tacky Glue white glue.
Hierarchy of Subaru:
(Click to see mine!)
Old 12-24-2004, 07:56 AM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
I use Tenax-7R and plastic weld
Old 12-24-2004, 08:46 AM
Rtuned's Avatar
Rtuned Rtuned is offline
(Gunze)Mr.Hobby Deluxe cement - I find it glue is much stronger than Tamiya, brush are the same. In 30sec, it will attach to the plastic especially those side mirror. When overnight, the glue is almost as strong as superglue.
Tamiya extra thin cement and extra thin superglue.
Old 12-24-2004, 08:52 AM
Wheelin75r's Avatar
Wheelin75r Wheelin75r is offline
Since this is a glue-question..... Does someone has a pic of what glue to use for the lenses of the lights? I can't seem to find the right glue for it.
Old 12-24-2004, 08:58 AM
Rtuned's Avatar
Re: Re: Main glue you use??
Use this...it will take more longer time to dry. But after dry, stain can be easily clean up and it glue as clear.
http://www.hlj.com/scripts/hljpage.cgi?MDLS104
Old 12-24-2004, 09:04 AM
Veyron's Avatar
Veyron Veyron is offline
I use Testors Model Master glue in the black bottle for general assembly.
One bottle has lasted me 12 years.
Old 12-24-2004, 09:29 AM
T\/\/iN-Tu|2Bo's Avatar
T\/\/iN-Tu|2Bo T\/\/iN-Tu|2Bo is offline
i used to use Testors glue back in the day Then i used Tamiya for a long while but got fed up with the same big-ass brush problem. Now i use Humbrol precision poly with the needle applicator. Works great! I also use Zap-a-gap thick type cyano glue and Welbond white glue for clear parts.
"If you feel in control. You're not going fast enough" - Mario Andretti
Old 12-24-2004, 09:51 AM
Technoman's Avatar
Technoman Technoman is offline
I always use Tamiya extra thin cement and Zap super glue. I use toothpicks to put glue on with normally.
I don't use glue for lights normally. I use a little Tamiya TS clear around the edges. Doesn't dry as strong as glue but it does hold and it's clear and never reacts with the paints I use (normally other Tamiya Acrylics).
Old 12-24-2004, 11:06 AM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
Super-glue (CA) and accelerator.
