Old 12-24-2004, 01:39 AM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
are these accurate turbo MAX outputs?
Max output from various turbos
TD05-14B (stock 1st gen) 275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
came off of vfaq..just wondering if its accurate(hp and boost)..[mostly the 16g's]
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 12-24-2004, 11:07 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: are these accurate turbo MAX outputs?
Those max outputs are with proper set ups and a well tuned car. I have a TD06H 20g on my RST and I am at 353whp at 18psi. It all depends on what you have supporting it! Now those numbers might also be Crank HP, not positive, but if you were looking for some good power out of a 16g, I would go with the Evo III 16g.
Old 12-24-2004, 11:13 AM
kjewer1 kjewer1 is offline
AF - Advisor
Those are decent wheel HP numbers, but that is the max for those turbos roughly. So that is assuming race gas and more like 25 psi. The 20g will do 27-29 psi before it starts to really run out of steam, but 450hp is appropriate (45-47 lbs/min max flow btw). I would assume 25 psi for the 14b and 16Gs, thats where people are running them at that HP level. THere are a shitload ov variables in supporting mods and tuning as Jake mentioned, but those are acceptable ballpark numbers.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-24-2004, 05:37 PM
thanks guys...
another question that you might be able to give me a approx. answer...
if i get a evo b16g turbo and evo manifold...and then UICP(on stock sidemount)... intake pipe... the free mods....strut bars.....190 fuel pump...550cc injectors.......plus what i have now which isnt much...what would be a safe boost to run and aprox HP amount would it give me.....
(im getting mbc tomorrow for x mas)
basically i dont have tons of money right to drop into the tranny(auto) like torque converter and all that good stuff
Old 12-24-2004, 05:44 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
you'll want a safc2, pocket logger and pump rewire kit. safe 15-18psi with sidemount....tuned 20-25psi w/ front mount.
DSM geek
Old 12-25-2004, 01:48 PM
so should i def get a 190 pump or just rewire or both?
and what exactly does safc2 exactly do? and pocket logger?
and with what you said...15-18 psi...what HP range you htink i'd be at?
thanks
Old 12-25-2004, 10:46 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
I figured i ask on this thread instead of a new one... Lets see if i get some answers... This summer im gonna turn my boost up... i already have a 255 fuel pump... i want to run about 20lbs on my big16g and the front mount will be hooked up. Do I just need injectors... If so, what cc will allow me to safely run this. Also... how much of a difference will Dsm link make in this combo and is it really needed? Thanks alot guys... Merry Christmas
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 12-26-2004, 11:41 AM
AF - Advisor
With a big/evo 16g, you should have a pump and injectors. I Ran the numbers and its too close for comfort. A 190 will be fine, and you should rewire in either case (at ~15 bucks its like a free fuel system upgrade). AFC lets you adjust your air-fuel ratio, and the logger tells you which way and how much you need to adjust (with some voodoo magic thrown in, can't be too easy). Without injector compensation I heistate to recomend over 550s, but for maximum power on the EVO16g they can fall short slightly. 660s will make a huge dent in your timing however with an AFC type device, but with DSMlink or a Keydiver chip I would go even bigger just because you can. In my case I run 950s with DSMlink becuase its the biggest injector this side of 1600s, and DSMlink runs it like stock. And I'm still at 85% duty cycle, but thats beside the point.
So this is why I say its importnat to decide on how you will tuning the car FIRST. That determines what your fuel system mods would be. With DSMlink or Keydiver chip/AFC do 950s and either pump upgrade (190 or 255/reg). With an AFC only do at least 550s, perhaps 650s, and have fun dealing with excessive timing until you get the ECU over the 2.1 g/rev mark (2g. 1g should be similar). If you dont plan to go for a record on this turbo, 550s will allow a good deal of power on both fuels (pump and race) and not bollix the timing too much. But upgrading twice is no fun either, I must have upgradd injectors 5 or 6 times. With all the money lost there I probably paid for DSMlink
Usually questions like this raise more questions than they answer, but I hope this is helpful enough. If I had to do it all over again, I would do DSMlink and 950s and be done with it, for whatever that's worth.
Kevin Jewer
Old 12-26-2004, 03:37 PM
thanks...it was actaully very helpful....but i do have a couple other ?'s...
1---i might be buying 550cc's used for 100..how do i kno they are 550's and not like stock or something???
2---and she said they have "bench work" done to them..which she said they flow better..no clue what that means???
3---and where do i goto get a fuel pump rewire...reg machanic???...what does it mean...just putting brand new wires on it???(newbie... i am)
4----might be getting a used ported sbr evob16g...how do i check for shafy played...wiggle the turbine?
thanks....sry about the lack of knowledge...learning everyday
Old 12-26-2004, 04:42 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Here's some info on why/how to rewire the pump:
http://www.roadraceengineering.com/fuelpumptechtip.htm
http://www.roadraceengineering.com/f...pflowrates.htm
http://www.forcedperformance.net/fprk2g_install.aspx
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 12-27-2004, 02:02 AM
thanks a lot....i get the concept and you have me directions and all...awesome
can anyone help me with the following:
3----might be getting a used ported sbr evob16g(under 1,000 mi)...how do i check for shaft play...wiggle the turbine?
Old 12-27-2004, 06:20 PM
anybody??...
might purchase this stuff this week ...help!?!?!?!?!
Old 12-27-2004, 09:02 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
3 yea just take off the intake pipe and try to wiggle the turbine around. it should spin freely but it shouldnt move any other direction
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-28-2004, 02:06 AM
thanks rob for the help...
anyone know these 2 ?'s.........
1---i might be buying 550cc's used for 100..how do i kno they are 550's and not like stock or something....dont they have certain colors...what color is 550cc?
2---and she said they have "bench work" done to them..which she said they flow better..no clue what bench work is??
\she ran 11.9's with a b16g and fmic and all the other goods\
Old 12-28-2004, 03:37 PM
AF - Advisor
1) Look for a part number or size engraved in the body of the injector. All FIC injectors have the size, I believe RC 550s have it as well, and I believe with Densos you have to look up the part number to verify.
2) All they can do is clean and flow test them. I doubt they made them flow much more, but equally important is verify that they flow what they are supposed to.
Kevin Jewer
