Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 12-24-2004, 12:27 AM
ericzepp ericzepp is offline
318 stalling problems-HELP!
The problem is intermittent stalling. It's fine for days. It stalls while idiling and sometimes while driving. Starts after a few minutes. Seems worse in rain. Extra throttle seems to help. Thank you for any advice!
Old 12-24-2004, 02:56 AM
89ltd 89ltd is offline
Re: 318 stalling problems-HELP!
what year is it?
Old 12-24-2004, 08:57 AM
Re: Re: 318 stalling problems-HELP!
Originally Posted by 89ltd
what year is it?
it's a '92
Old 12-24-2004, 09:24 AM
if it runs normal otherwise, I would think it would be the hall effect pickup coil in the distributor, had the same thing happen to me, it was very hard to pin down because it didn't through any codes until it finally stopped working.
Old 12-28-2004, 01:19 PM
replaced the hall effect pickup coil, but the problem still occurs. Last night, it died while my foot was on the gas pedal. I let off the gas and pushed the pedal again and nothing happened-then I did it again and it jerked and started up again. Any more ideas would be appreciated!! Thank you again!
Old 01-19-2005, 02:52 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
did u try looking at ur spark plug wires have some one start the van then get to the engine and with a spray bottle spray down the spark plug wires and see what happens if u see any sparks then u should replace the wires and y not the plugs to because i no how much of a pain it is on those things
Old 09-05-2005, 09:57 PM
fancydancer fancydancer is offline
Wink
had the same problem with my van. See my post dated 6-7-2005. replaced the crank sensor then drove from NJ to Flordia without a problem. Its been running great ever sense.
