Old 12-23-2004, 09:59 PM
MasterChief1724 MasterChief1724 is offline
A Scanner
I have a ScanMagic 1200 UB Plus and I would like to use it. The thing that sucks though is I have no disk. My mom got it free when she signed up with EarthLink some time back but I have no disk. Are there any sort of drivers or programs I could get that would allow me to install it without the disk? Or am I pretty much screwed and now I have a useless scanner?
Whoever said nothing is impossible never tried slamming a revolving door.
Old 12-23-2004, 10:00 PM
my3rdskyline's Avatar
my3rdskyline my3rdskyline is offline
Send a message via AIM to my3rdskyline
Re: A Scanner
try the manufacturers site for drivers. or sometimes it will just work with windows (if you're lucky)
http://help.earthlink.net/techsuppor...magic1200.html
http://www.mustek.com/download/driv_...sh/1200ub.html
Old 12-23-2004, 10:04 PM
Re: Re: A Scanner
oops it's the UB plus
http://www.mustek.com/download/driv_...200ubplus.html
direct link:
http://mustekmu.brinkster.net/Downlo...200UB%2BXP.zip
Old 12-24-2004, 03:33 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: A Scanner
I have an older Mustek scanner. Had to use their little trick to get it to work with Windows XP. Had to rename the OS to Win2k in the regsitry, install drivers for Win2k, and then rename the OS back to WinXP. Worked just fine, but you'd think they'd just make WinXP compatible drivers....
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 01-06-2005, 09:26 PM
Re: Re: Re: A Scanner
I got everything installed. The program and scanner seem to work well. But I scanned a picture once and I have a question. Where the hell does the pic go?? I saw nothing saved or anything. Did I just run the scan wrong or what?
Old 01-07-2005, 09:12 PM
Re: A Scanner
try to open an imaging program. do some google searches for "TWAIN" and you should be all set
Old 01-07-2005, 09:27 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: A Scanner
Twain32 is your friend.
