Old 12-23-2004, 05:44 PM
Alexxn 00 Si Alexxn 00 Si is offline
Bad Alternator ?
My 2000 Blazer LT 4.3.....noticed tonight that my dash lights were dim and I could hear a whining from my speakers, only had my headlights on....tested it with a Voltmeter and it read roughly 12.23 volts at idle BUT.....when I rev the motor it goes to 14 volts....could this be the alternator ? Battery is only 6 months old, AC Delco....
Thanks !
2005 Chevrolet Silverado 2500HD Ext cab
Old 12-23-2004, 08:17 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Bad Alternator ?
Yip, the alternator is not producing the right voltage.
This could be caused by a bad battery with an internal short or the alternator has bit the bisket early.
I would get a warranty replacement. It is covered by a years warranty.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-25-2004, 01:23 PM
Yep, alternator was the problem....got a Bosch rebuilt at NAPA (it's nice to have a buddy there !) and now it reads 14.7 volts at idle with EVERY accessory I could think of on plus the headlights.
Thanks BlazerLT !!!
Old 12-26-2004, 03:22 AM
BlazerLT's Avatar
AF -Advisor
You are welcome!
Glad to see you happy.
Old 01-08-2005, 05:15 PM
Well I THOUGHT all was well.....now all of a sudden when I am idling the Vots drop all the way down to 12 and then back up to 14......if you sit and idle about every 30 seconds or so this happens, the lights dim, and then it goes back up to 14.
New alternator gone bad ??? I am getting so frustrated with this truck now...
Old 01-08-2005, 05:35 PM
BlazerLT's Avatar
AF -Advisor
I would get your battery tested.
If it will not hold a charge, the alternator will be constantly working to keep the battery up to snuff.
This will burn it out in short order.
Old 01-09-2005, 04:36 PM
Battery tested 100 % OK....
Old 01-09-2005, 05:05 PM
blazee's Avatar
blazee blazee is offline
Problem?
Check all of your wires and connections, make sure they are tight and in good condition. Also make sure the mounting bolts are tight. Look and see if the belt shows signs of slipping.
Old 01-09-2005, 05:15 PM
blazee's Avatar
Problem?
Also make sure your battery is fully charged before you connect the new alterator, or your alternator will be DOA.
Old 01-09-2005, 06:42 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Bad Alternator ?
Who tested it?
Did you hook up an voltmeter to it?
Old 01-09-2005, 07:15 PM
I took it to Autozone and they checked it...
Old 01-09-2005, 07:21 PM
BlazerLT's Avatar
AF -Advisor
Teheheh, don't trust them.
Take a voltmeter out and connect it to the battery when the engine is off, and again when it is running.
Old 02-08-2005, 11:49 AM
OK now that we finally had a nice weekend I decided to dig into this again....Voltage at the battery with the engine/key OFF - 12.76 volts, Voltage at the battery with the engine RUNNING - 14.58 volts.....
I went ahead and got a warranty replacement alternator and installed it. Voltage reading with the new alternator and engine running is 14.61 volts.
STILL having the same problem, many times after coming to a stop and mostly at night the volts will drop down to 12, then rise back up to a little past 14. I am also noticing that when idling with the turn signals on the volts needle will bounce back and forth slightly...
Is any of this normal ? I NEVER noticed this before with my original stock alternator....
Any help is appreciated !
Old 02-08-2005, 01:40 PM
BlazerLT's Avatar
AF -Advisor
The needle bouncing with the signal is normal, the dropping to 12v is not.
It ONLY happens at night?
Old 02-08-2005, 01:42 PM
Yep...I've only noticed it in the evenings when my headlights/dash lights are on.......BUT doesn't do it everytime I stop either....
