Old 12-23-2004, 01:01 PM
Pimpdady753 Pimpdady753 is offline
Air intake Manifold help
ok im going to be getting a new bottom and top air intake manifold.
is this one any good. http://cgi.ebay.com/ebaymotors/ws/eB...941917496&rd=1
it comes with the top and bottom.. also how hard is it to put one in and take the old one out. and i have a stock hood i wont have to get a new hood will i. some one help me thanks alot.
Old 12-23-2004, 06:01 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: Air intake Manifold help
Hey that place is only 60 miles from me!
If you have a foxbody 'stang it's a bolt-on. Just don't overtorque the bolts and you'll be fine.
If you have a '94-95 GT you'll need an elbow from Edelbrock, TFS, or FRPP and you may have to cut or remove the hood liner to prevent rubbing, otherwise it's a bolt-on.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 12-23-2004, 06:20 PM
andrewespo's Avatar
andrewespo andrewespo is offline
It's not that bad just need to take the throttle body and air intake off. Then remove the manifold (simple it's 6 bolts). The bottom is a little bit more, disassemble the fuel rail and lines, remove injectors, and disconnect all hoses then remove (8 bolts). Make sure to get a new grommet-pcv filter, and gaskets. Put some penetrating oil on all the bolts to loosen them up. When I installed my intake manifold 2 bolts in the lower manifold were seized into the heads so I had to have them machined out.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 12-24-2004, 06:14 PM
is it a good one. and what is a foxbody mine is a 1990 GT. i think i know what your talking about.
Old 12-24-2004, 11:08 PM
ok i got the top part off, ive herd that you need a tool to get the injectors out, what is it called?
Also off the subject, can i get a pully that goes on my alt. that makes it spin faster, so it puts out more power. Thanks
Old 12-25-2004, 02:09 AM
Nope, your alt. puts out max amps between 2500-3000 RPM anyway. Most guys run underdrive pulleys to decrease drag on the motor.
Tool for injectors? I use my bare hands. Just work them back and forth and pull firmly, put a little oil on the O-rings prior to re-installing. Don't even have to disconnect them from the wiring if you don't want to.
Freedom Isn't Free.
Old 12-25-2004, 02:37 PM
spy604's Avatar
spy604 spy604 is offline
Send a message via AIM to spy604
a foxbody is a mustang built on the fox chassis, being 79-93 year wise.
We're all living in Amerika
Amerika ist wunderbar
"So where'd you get the beauty scar, tough guy? Eatin' pineapple?" / "How ya getta scar like that from eatin' pineapple, man?"
-Scarface, TV Version
1986 Mustang GT, Black, T-Tops, Very tired 5.0
Old 12-26-2004, 01:15 PM
yeah that is what i thougth with the fox body.
