Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-23-2004, 10:50 AM
joesix joesix is offline
My car is overcooling
I have a 93 civic cx hatchback and now that cold weather has arrived i've noticed a strange problem. When the engine is at normal temperature at idle and i turn the heater on the temp will drop almost down to cold in about 5 minutes is this normal???. I've checked the themostat it opens and closes fine and the gaskets and seals are fine, should I put a higher temp themostat in or is there some kind of cooling system problem.
Old 12-25-2004, 01:20 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
Re: My car is overcooling
I dunno drop in voltage to the temp sensor? get out there with a voltmeter and check things over.. I do notice in my car there is a definite voltage drop wfrom when the car is in driving revs to when it is sitting at a light with the heat on high.. you notice the lights dim a bit from normal driving, and the fan actually sounds slower (when at full blast) until you start up again, and everything goes back to sounding like normal, and the lights brighten up.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 12-25-2004, 09:21 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
that is normal, the heater core takes the ambient fluid from the motor and pushes it towards the core, cooling the motor.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-27-2004, 12:59 AM
car_boy_16 car_boy_16 is offline
Get a higher temperature thermostat, nothing lower than 180, preferablly a higher temp than that...Like crxlvr said, the heater core is acting as an extra radiator, and that is exactly what it is! So when you use your heater it's cooling down the coolant too much and your coolant isnt warm enough - I bet your heater isn't heating as well either huh....
Old 12-27-2004, 07:00 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
try replacing both the thermostat and the radiator cap, most people overlook the radiator cap but it is actually a very critical part in the cooling system because it keeps the pressure in the system which is what determines the boiling point of the coolant.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
