Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 12-23-2004, 10:48 AM
mikeypooh1 mikeypooh1 is offline
Help! broken speed sensor
The little plastic thing that connects to the speed sensor fell in to the tranny when it didn't have any fluid. It got pushed in by my inlaw so I cant retrieve it without removing the tranny. What would happen if I were to leave it in there and put another one in? Or do I have to remove the tranny? I have a 1995 dodge neon MTX.
Thanks in advance.
Old 12-25-2004, 01:32 PM
rruddfan21 rruddfan21 is offline
then you will obviously have that little piece getting pushed through the tranny when you try to drive it, possibly causing serious damage to the tranny. you need to locate it and find it. not sure where you dropped it but you need to get it out.
Old 12-06-2005, 09:18 AM
josephplaw josephplaw is offline
Re: Help! broken speed sensor
Hi, Speedometer and odometer not working. can anyone help to fix problem. im not mechanic but learn quick. Thanks Joe...
Old 12-06-2005, 09:49 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: Help! broken speed sensor
Search and you will find your answer....
http://www.automotiveforums.com/vbul...hlight=CLUSTER
