Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 12-23-2004, 09:17 AM
cdubb cdubb is offline
ride height...!
k im thinking of lowering my del sol, i was wondering what do i need to buy just coilovers? whats the best way to go i want to be able to adjust it since i am probably gonna put new fender bumper and side skirts in the coming months, im also gonna buy new tires/rims in the springtime so i wanted it preped for that also...thanks!
Old 12-23-2004, 03:03 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Depends on what size wheels and what tires. If by coilover you really mean just new springs, then its a bad idea. Your stock shocks will not last very long. Get some that include a new shock and spring. Also id say if your going more then 3/4 of an inch drop, a camber kit would be a good idea as well.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 12-23-2004, 08:28 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: ride height...!
I think the camber is safe up to about an inch and a half. Anything more than that will need a camber kit.
If you want adjustable, then a full coilover kit is the way to go. Buy from a reputable company - you'll thank yourself in the long run. Tein makes very good products if you decide to buy from them.
AudioGuy93DelSol's right - you'll need to decide on what size wheels and your tire demensions before you'll know how far to drop the car and what setup will work best for you. Some coilovers will only drop you so far. You need to plan ahead so you'll know which products to purchase.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 12-24-2004, 01:28 AM
ok great, well id like to add a full coilover kit and jus lower it for now with my stock wheels (IM using the tires off a 1998 civic they are 14 inch nordic winter tires)
is it possible to add a full coilover kit now that will accomadate the tires and wheels i buy in the spring????
Old 12-24-2004, 05:09 AM
Re: ride height...!
Figure out what wheels and tires you want, and then buy the coilover kit accordingly. If the kit's adjustable, you can lower it a little now with your current wheels (should look fine) and can fiddle with the ride height later once you get the new wheels. Shouldn't hurt anything or your current setup.
