Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 12-23-2004, 08:13 AM
88zccivic 88zccivic is offline
engine light at 115-120 mph?????
i have a 90 civic std hatchback this is some of the more important mods
-dohc zc
-89 integra ecu
-t25 turbo
-msd ignition
-450cc injectors
-apexi safc
-255lph fuel pump
i am running 10psi this car never has a light till every time i hit 115-120mph
i pulled over and looked at the codes and it gave me o2 sensor, map,speed sensor
turn it off and start it back up and its fine again any ideas?
Old 12-23-2004, 09:20 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Take it to a dealer and have them find out the exact code so you know exactly what went wrong and not a list of things that could have cause the code.
Old 12-23-2004, 08:12 PM
97integrals's Avatar
97integrals 97integrals is offline
drive the speed limit!!!!!!!!!!!!!!!!
Old 12-23-2004, 08:17 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: engine light at 115-120 mph?????
maybe thats your engine's way of yelling at you for driving that fast??
Old 12-24-2004, 01:20 PM
thanks for the help polygon
ill try that
Old 12-25-2004, 09:01 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
other thing would be to remove the speed governor... but you should'nt be going over 80mph anyways.. except at a dragstrip, and even then you'd be lucky to get up to 90mph..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 12-26-2004, 05:26 PM
sivic02's Avatar
sivic02 sivic02 is offline
the lights are from your engine craping on itself when it realizes how fast its going, i say take her to 130-140 and see if she still does it!
Here's to being single, seeing double, and sleeping triple
