Go Back   Automotive Forums Car Chat > Isuzu > Amigo
Old 12-23-2004, 08:49 AM
muss03 muss03 is offline
ignition stuck please help
First off, I really dont know much about cars so any suggestions would be greatly appreciated. I have a 1990 Amigo 4x4 which I drive in the winter and in bad weather. We had a snowstorm yesturday and I drove the Amigo all day, no problem. I get in today, put the key in the ignition and it wont come out of the lock position. Its happened before and I would just remove the key, put it back in the ignition and it would go to the start position.
I've been messing with it for an hour and its not budging. It really sucks because we have about two feet of snow now and I cant get the damn key to work. The amigo is old, it has a ton of miles on it, rusted and ugly as hell but Ive never owned a more reliable vehilcle when it comes to snow and freezing temperatures. I dont plan on putting a great deal of money into this problem, I just want the damn thing to start, one way or the other. Thanks for any and all suggestions
Old 12-31-2004, 06:29 AM
GTES-t's Avatar
GTES-t GTES-t is offline
I realize that this is a bit late, and you may have fixed/sorted out the problem. But I was just wondering if you've tried rotating the steering wheel back and forth while trying to turn the key. I have this issue with both my Amigo and our other car. The steering wheel ends up being locked with pressure on the lock pin, which doesn't allow it to retract as you try to turn the key, which in turn doesn't allow the key to turn. I often have to wiggle the steering wheel a bit to get my key to work because of this.
Hope you already fixed your problem, and if not I hope this helps you out.
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
