Old 12-23-2004, 06:35 AM
paulfischer paulfischer is offline
Rough Idle after car sits for about 20 minutes
Was wondering if anyone could shed some light on this.
My 99 Lumina LTZ 3.8 sometimes has a rough idle after the car has been driven, than turned off , than restarted in about 20 minutes. I Get a rough idle on restart, than it goes away after a minute or two. No check engine light.
Thanks for your help!!!!
Happy Holidays!!
Old 12-23-2004, 03:37 PM
Fireplug Fireplug is offline
Re: Rough Idle after car sits for about 20 minutes
Sounds like a injector leak
Old 12-24-2004, 02:32 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Or a fuel pressure regulator bleeding down sometimes
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-27-2004, 07:23 AM
I've already replaced the fuel pressure regulator this past summer.
How can one tell if an injector is leaking?? I have visually checked the injectors, and do not see any fuel leaking out.
Would an EGR valve or o2 Sensor cause it??
Thanks!
Old 12-27-2004, 07:29 AM
That EGR's position is monitored by the ECM, it should code if the EGR is not working right.
If you have acess to a fuel pressure gauge, check for pressure bleed off when you shut it down and let it sit for the time indicated.
Does this happen consistantly, or randomly?
...empty gun rack.
Old 12-27-2004, 07:33 AM
it happens randomly.......
Will get a gauge this afternoon and check pressure
Thanks Again!
Old 12-27-2004, 08:37 AM
another question...
why would it only do it when the car is warm? (the problem is not consistent) if i let the car sit for a while or overnight, it starts rights up.
Old 12-27-2004, 09:04 AM
Well, ignition modules are usually suspect when the problem seems to be brought on by heat, but usually results in a run/no run situation, not just poor running. Generally they will cause it to die, then start right up after cooling off. Doesn't sound like what you've got.
You might want to check that the IAC and it's bore are clean.
...empty gun rack.
Old 12-27-2004, 09:11 AM
where is the Idle Air Control valve located on this engine?? 3.8
also replaced the coils last summer too.
Thanks!!
Old 12-27-2004, 09:18 AM
jeff,
found the IAC. I'm assuming its ok to clean with carb cleaner.....
How does one tell if its bad, besides bench testing it??
its only $35 @ Napa, so I might just pick it up.
Could dirty injectors cause the problem also??
Old 12-27-2004, 12:05 PM
If an injector pintle was cruddy enough that it couldn't close completely, it would empty out the fuel pressure behind it into one cylinder, and cause a wet-foul miss until cleared out.
...empty gun rack.
