Old 12-23-2004, 05:55 AM
GvEman's Avatar
GvEman GvEman is offline
Exclamation How To Build a Roll cage
This is a simple how to build a roll cage. This cage is made to fit my Impala.
To build a roll cage you need:
* Styrene rods
* Knife
* Pensile
* Ruler
* Tape
* Paper
And it's never bad to have some references.
This is the reference I used.
This cage was made in 1 3/4" chrome moly. So I took the closest rod I had, 1,5 mm.
1. Measuring
Let’s start of with making measurements. For me it was easy. I measured the with of the roof at the impala just to see how wide it could be at a maximum. It was about 50mm.
The with of the cage needed to bee 61mm other wise I must squeeze it in place.
I also draw the side supports.
When I am done with that I draw another one that looks the same.
And cut it out.
Then I test the paper cage in the car, to see how it will fit.
2. Bending
I start with taping the styrene rood on to the paper.
And then I start to bend the rood as close to the drawing as possible.
After that I remove the tape. And test the cage in the body (no picture).
I do the same with the rear supports and this is how it looks with one of the rear supports.
The last step is to glue the cage to getter.
I am going to chrome the cage later on and put on some soft material on it so it will look like this.
I got the reference from
I hope this will be to help fore some one.
Best Regards
Anton
Old 12-23-2004, 08:54 AM
lilbudman's Avatar
lilbudman lilbudman is offline
Send a message via AIM to lilbudman
Great tut man, I'll defiantly be using this on some of my upcoming projects.
Lil'budman
Thanks to me for learning how to make my own God damn sigs!!! J/k If anyone needs a sig PM me.
Old 12-23-2004, 08:59 AM
i6oR i6oR is offline
THANK YOU SO MUCH dude i started one but i cant finish it THANKX AGAIN
Mi CaR
Old 12-23-2004, 09:34 AM
sportracer02's Avatar
Hi,
a well done tut.
Don´t you have problems that the rods want back to their originate position?
I think the hardest thing to do is the cage-part starting at the b-post area along the drivers side window - a-post - front-window - dashboard. Getting both sides equal is a mere try and error.
Micha
Old 12-23-2004, 12:43 PM
Dr.AK's Avatar
Dr.AK Dr.AK is offline
Re: How To Build a Roll cage
Lil'budman
Yeah! Me too! That's a great tut!
Old 12-23-2004, 01:42 PM
i just cant get it done the cage i just dont know the mesuremnts (BTW its my first car)
Mi CaR
Old 12-23-2004, 02:38 PM
GvEman's Avatar
Measure the with of the interior tub and then the with of the roof.. then you draw it on paper and then you cut it out and then deside about the hight of the cage
Best Regards
Anton
Old 12-23-2004, 05:06 PM
ATMDC's Avatar
ATMDC ATMDC is offline
when you said max it could be was 50mm, did you meant to put 60mm? by the way this is a great tut, and i will use this no doubt
Old 12-24-2004, 04:55 AM
GvEman's Avatar
Re: Re: How To Build a Roll cage
the max it could be was 50mm at the roof. and 61mm at the botom.
Best Regards
Anton
Old 12-24-2004, 07:42 AM
thankx youthe same thing but with more explanation or just less to read which i love and ill try that man. thank again GvEman
Mi CaR
Old 12-24-2004, 12:55 PM
Great tutorial! Who would've thought of drawing it on paper first, then creating the parts.
AF MODELING FAQ
"Oh what a feeling.- Toyota
