Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-22-2004, 09:31 PM
betorn betorn is offline
headlight adjustment,Popcycle sticks don't cut it
How do you adjust headlights that seems to have not one adjusting screw? Now using popcycle sticks to get headlights from pointing down to the ground. Numbers on light bulbs are hb4 for low beams and hb3 for high beams. Is this correct? (1992 model year.)
Old 12-23-2004, 07:29 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: headlight adjustment
Do you have the old style glass headlights or the newer plastic enclosed ones?
Old 12-23-2004, 08:22 AM
6502dude's Avatar
6502dude 6502dude is offline
There is not one. But, there are three adjustment screws.
They are are found under plastic access panel, over headlight (lift hood).
Rotate plastic nut around to move screw in or out. There is likely a "special tool" for this.
Why adjust? Unless you have been in an accident or replaced lens assembly, the alignment should be okay.
Old 12-23-2004, 08:43 AM
6502Dude, he said the headlights are pointed toward the ground, so either accident or just bought it...
Old 12-25-2004, 03:27 AM
grimor's Avatar
grimor grimor is offline
for help adjusting your headlights/aiming correctly there is a nice write up at www.danielsternlighting.com
