Old 03-05-2002, 11:59 AM
94civic's Avatar
94civic 94civic is offline
speaker wiring
i'm wiring two brahma's in paralell so it can run at .5ohms and the amp puts out 800wattsx2 @.5ohms,the problem is if i'm wiring them in paralell how would i hook them up to two channels(one sub per each channel). Also if i was to paralell one sub i think it will present a 1ohm load(correct me if i'm wrong) then i will be able to run each sub at 1ohm by hooking them up to seperate channels if i was to do this to both right?
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 03-05-2002, 12:43 PM
starkfu's Avatar
starkfu starkfu is offline
Send a message via ICQ to starkfu Send a message via AIM to starkfu Send a message via Yahoo to starkfu
are these subs dvc? is your amp a two channel?
for example, if you have two 4 ohm per coil dvc's and a two channel amp, you would parallel each sub together, creating 2 2 ohm subs, then if you parallel those together you essentially have a one ohm sub, when you bridge the amp and connect the sub, the amp will internally cut the ohm load in half, cause you are basically paralleling the amp's output.
If you run one paralleled sub at 2 ohms to your 2 channel bridged you will have power rating at one ohm, or you can run 2 ohm stereo with both subs, one to right channel one to left, this is sometimes a better way to go, but i need to know more to give better suggestion.
***If knowledge is power, then a god am I***
<<former PH abyss member>>
1991 Acura Integra GS mods:
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Power slot rotors and EBC pads
Gutted
Blown motor
Looking for B18C5
1994 Honda Accord EX
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Just bought this car, more to come.
Old 03-05-2002, 02:35 PM
94civic's Avatar
here is some info on the subs
http://www.acoustic-visions.com/brahma.htm
they are dvc and are 2ohm subs. the amp is a Audiobahn A2200HCX 2 channel. Now on the spec sheet the amp can run at .5ohms stereo putting out 800x2 watts. Now the thing is when i paralell the subs they will give me a .5ohm load and i wanted to hook up each subto each one of the channels to send 800 watts to each sub. or also what i was thinking is that i paralell each sub seperately to get a 1ohm load and hook it up, but it will only put 600 watts per channel and thats not enough for the subs(1600 watts RMS 4800 peak) neither is 800, but 800 is better than 600. Here is a clip from the specs sheet:
RMS Ratings: 200 watts x 2 @ 4 ohms stereo, 400 watts x 2 @
2 ohms stereo, 600 watts x 2 @ 1 ohm stereo, 800 watts x 2 @
½ ohm stereo, 1600 watts x 1 @ 1 ohms mono
is it possible to have the subs wired at .5 ohms and them up to the amp in a seperate channel for each sub or can i paralell the seperately so they can run at 1ohm and hook them up in seperate channels. it will be better if i can go with the first option of wiring them at .5ohms. Another question can't i just wire them in .5ohms and bridge the amp at 1ohm so it can send out the full 1600 watts. Thanks for your help
too much to list
Old 03-05-2002, 02:58 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Sorry not possible to get TWO 0.5 ohm loads...
With a DUAL 2 ohm voice coil sub you would get a single 1 ohm load... so you would have TWO 1 ohm loads, OR a single 0.5 ohm load... (say goodbuy to your Audiobahn amp as it goes up in flames with this load!!) or of course you could also have a SINGLE 2 ohm load but thats it my friend
AF's Official Asshole
RIP AUNIE
Old 03-05-2002, 03:29 PM
94civic's Avatar
well i heard that this particular amp stays pretty damn cool whil it's running at .5ohms.
too much to list
Old 03-05-2002, 04:02 PM
starkfu's Avatar
yea, sparq is right, you would have to run 1 ohm stereo, or .5 ohm bridged, personally even if it says it can handle the load, I would not do this, I try never to go below 1 ohm loads, even then I don't like doing it and only will with certain brands of amps.
In my personal opinion i would series each coil to 4 ohms then parallel the two subs for a two ohm load, then run it to the bridged output of the amp to acquire the output of a 1 ohm bridged power rating. so this would give you your 1600x1 mono rating which is basically giving you the 800 per sub.
realistically you aren't getting that much anyway, even though this amp is fairly efficient you lose about 40 percent in heat and maybe another percent or two to wiring and connections. so you may get in the neighborhood of 450 watts per sub.
Keep in mind, power is nice to have, but is not sole dictator of sound. cleanliness and box design are the two major factors.
for example kicker used to make a sub (XPL) that required 100 - 150 watts max power, and this thing outperformed most other subs of that time. It took a larger size box then most, but the gains were well worth it.
just something to think about.
good luck
greg
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Gutted
Blown motor
Looking for B18C5
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Old 03-05-2002, 10:36 PM
sparq's Avatar
AF Premium User
Audiobahn amps DO NOT RUN COOL! I dont know who the hell told you that but they are full of shit! The only way you are going to get an Audiobahn amp to run cool, ESPECIALLY at 0.5 ohm MONO would be to strap dry ice to it!
Its not a bad amp, but it is not designed to handle 0.5 ohm MONO loads, in stereo yes... but not mono, thats a 0.25 ohm STEREO load to the amp... VERY VERY VERY VERY VERY VERY few amps on the market can handle this sorta thing, and they are designed SPECIFICALLY for that type of thing (usually amps designed for SPL where SQ from the amp dont matter and they basically deliver what is called a "square wave" to your subwoofers) not good on the ears, nor good on your nice woofers... I say you go 2 ohm mono, will keep the amp from running TOO hot, and still deliver the power and SQ... as typically when the ohm load drops, so does the quality!
RIP AUNIE
AMP/Speaker wiring in cooler boom box Chupacabra111 Car Audio 6 12-20-2010 05:29 PM
Speaker wire replacement mikeburrit01 1st Gen 95-99 0 09-27-2010 09:31 PM
speaker wire colors at the speakers iowabucks Grand AM 4 02-08-2007 11:25 AM
Question about the speaker wires in my Civic... SilverY2KCivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 12-29-2001 05:20 PM
Question about the speaker wires in my 6th gen Civic coupe... SilverY2KCivic Car Audio 1 12-29-2001 05:20 PM
