Old 12-22-2004, 07:28 PM
minivan minivan is offline
code 1350 or1450 translate please
Runs fine . Went to auto zone,had checked,it was 1350 or 1450,I think 1450,to do w/emissions.The parts seller said any time they get a 1300 or 1400 code it had to go back to the dealer.
Any ideas?
Old 12-22-2004, 11:49 PM
Mackab Mackab is offline
Re: code 1350 or1450 translate please
P1450 - Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1350 - Ignition Control System
www.wattora.com/Mods/OBDII/
Old 12-22-2004, 11:54 PM
forgot to add the following link which explains the P1450 possibilities:
http://www.thedieselstop.com/faq/9497faq/tsb/tsb/files/010708.pdf#search='windstar%20p1450'
Old 12-23-2004, 06:00 AM
DRW1000 DRW1000 is offline
Just to clarify the Dealer return comment.
As far as I am aware any codes that begin with P0... are generic codes across all manufactureres of any OBD11 compliant vehicle. The P1... are manufacturer specific.
This may be why they made that statement.
Old 12-23-2004, 07:45 PM
wiswind wiswind is offline
Do you have a locking gas cap?
If so, try a "non-locking" gas cap as the locking type almost always fail emissions testing (and can cause a CEL)
Also, check to see that your gas cap seals correctly.
Old 12-24-2004, 08:57 PM
martymoose32 martymoose32 is offline
about the gas cap thing?? are you supposed to hear a hiss when you remove the cap? kind of like relieving pressure in the tank. My van never makes that sound. I know the fuel system is pressurized. is it right??
Old 12-25-2004, 06:32 PM
It depends on the conditions, but YES, your cap needs to be able to maintain a certain amount of pressure. I know that, for emission testing in Wisconsin, that they check to see if your gas cap and fuel tank will hold pressure.
This is how I know that locking gas caps almost always fail.
I would guess that the cheapest way to see if it is your gas cap, would be to replace it.
Or, if you can have it checked at a garage for free?
These would be an idea for a cheap and likely cause of your problem.
My owner's manual clearly states that the CEL can come on due to a loose or improperly seated gas cap.
