Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-22-2004, 06:51 PM
THiNkr4x4 THiNkr4x4 is offline
Differential changing
can I use atf in differential on my 96 trooper ??????????????? need to know
Old 12-23-2004, 01:53 PM
Bigpoppax2 Bigpoppax2 is offline
No, you cannot unless you want to crater it. Gear lube, and use the lsd additive if you have the LSD option.
Old 12-24-2004, 01:48 AM
Re: Differential changing
Thank You soooooooooooooooooo much
Old 12-24-2004, 12:21 PM
95.5 Rodeo's Avatar
95.5 Rodeo 95.5 Rodeo is offline
If you want to know if the limited slip differential is installed in your Rodeo, check for option code G80 on the plate in the engine bay.
http://www.itog.com/xr-001.shtml
Dale
Old 12-28-2004, 07:41 PM
can I use the lsd additive even if I dont have lsd
Old 01-03-2005, 07:55 AM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
Re: Re: Differential changing
I was wondering the same thing. I don't have the option code that says that I have the Limited slip dif. but I am thinking it is one by the way it reacts when the wheels are spinning.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
