Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 12-22-2004, 06:11 PM
h2omansd h2omansd is offline
programming radio code
I have a 2002 acura mdx. I have the radio code that needs to be programmed into the unit (I changed the battery, which wiped out the original cod). How does one go about programming the code into the radio? thx
Old 12-23-2004, 02:51 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: programming radio code
the search function is your friend my friend. an easy answer is go to your local honda/acura dealership. your problem will be solved in 5 mins or less.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-29-2004, 08:48 PM
mwkirchner's Avatar
mwkirchner mwkirchner is offline
It is VERY simple.
Turn on the radio. You should see the word CODE in the display. You have the station preset buttons on the radio ... numbered 1-6. The code will be something like 12623. You just punch the numbers in that you have for the code and when you get to the 5th number you should hear a beep and the radio should come back to life..
Old 01-03-2005, 11:19 AM
CBURKE's Avatar
CBURKE CBURKE is offline
go to the honda/acura dealership.
