Old 12-22-2004, 03:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Bulge in side of tires
From the many months of peeling put, burnouts, and 180s, my front tires now have bulges on the side of them. It's not BAD bad, but they seen better days. Myt question is, is it recommended to still drive on them? Obviously, im going to need new tires, but they're not just going to blow out, are they? The tread is still in great shape (somehow), but they bulge. Im going to do a tire rotation, b.c. tje back ones are fine. Im not doing anymore stupid stuff, so should they last?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-22-2004, 03:35 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Bulge in side of tires
Are the bulges just on the bottom? If you're sure it's not underinflation, then I wouldn't drive much on tires that have ripped cords.
Old 12-22-2004, 03:58 PM
Legionofone's Avatar
Legionofone Legionofone is offline
general rule bulge = bad...
if u plan on driveing at high speeds get them repaced asap... its a weakness and if u push them they will bow and it will be catostrophic especialy on the front wheels...
Old 12-23-2004, 01:17 PM
david-b's Avatar
Dave is THAT guy
I guess the bulges were on the bottom, but when you drive, the wheels turn. I know what you mean, and no, its in the same spot all the time. Not the low pressure bulge, but a bad bulge. I guess I should stop doing 100+ coming home form work now. Would rotating them work? Throw em on the back.
75 Monte Carlo
Old 12-23-2004, 01:45 PM
GSTRacerNVUS GSTRacerNVUS is offline
Re: Re: Bulge in side of tires
LMAO... I know what you mean being a chick and all.
Yea, this guy sold me a couple tires with bulges in them, and a week later one blew... then a week after that the other one did... So I'm guessing that it's time for some new "feet" for your car.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 12-23-2004, 03:54 PM
george536's Avatar
george536 george536 is offline
I would get them replaced just to be sure. You dont want a tire to blow out on you on the freeway. Well if you have awd thats another story. You probably wont feel it.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 12-23-2004, 08:27 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
tire bulge is bad. i would get them replaced asap. i had tires bulge on me and i found out it's from potholes and stuff like that because low profile tires don't have much of a sidewall so it takes all the pounding and that's why they bulge. with a bulge they can blow out at any time.
95 Talon TSI AWD
97 Eclipse GST
