Old 12-22-2004, 01:06 PM
GAWKY's Avatar
GAWKY GAWKY is offline
Send a message via AIM to GAWKY
Question Winter Startup?
I live in michigan and have a 1991 sierra w/efi i was wondering how i should start it on cold mornings, it stays outside all the time, i heard that you should pump it a couple times before you turn it over but would that do anything w/ efi.
Old 12-26-2004, 09:26 AM
Will2 Will2 is offline
Re: Winter Startup?
Don't pump it. If the auto choke is working correctly you shouldn't have to. Pumping it will cause gas waste and possible flooding. Pumping it came from pre electronic ignition systems.
Old 12-26-2004, 09:28 AM
Re: Re: Winter Startup?
I live in Michigan also. I don't pump the gas peddle on any of my vehicles.
Old 12-28-2004, 08:02 PM
rabt's Avatar
rabt rabt is offline
pumping doesn't do a thing to an EFI vehicles (bad or good)
Old 01-04-2005, 04:04 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Winter Startup?
dont pump, the buzzing sond you hear b4 your start the vehical shoule be let go until the end, its a prime charge (same as pushin the peddel a couple times on a carb moter), and let it run for a good 4 or 5 min for oil to start to flow, oil wont freeze but it will get really thick, i live in michigan too, and cold mornings are a bitch, but i would rather spend the few min worth of gas over what an under oiled engin could cost
