Old 12-22-2004, 11:15 AM
MarineJAG's Avatar
MarineJAG MarineJAG is offline
Question Line-X vs. Rhino Liner
I'm thinking of having a liner sprayed onto my truck bed... Which spray on type liner is best, Line-X or Rhino Liner? Does anyone have good/bad experiences with either?
2001 GMC Sierra 1500 (Wife's)
2003 KeiferBuilt Genesis X-3 (mostly Wife's)
2000 Sebring Convertible Jxi (Mine... most of the time)
Old 12-22-2004, 11:38 AM
buttnekked buttnekked is offline
Re: Line-X vs. Rhino Liner
do a search for line-x in this forum. There was a thread about this a few weeks ago with people talking about how their liner was put in and how it looked.
Old 12-22-2004, 01:52 PM
bowtieguy bowtieguy is offline
I have a rhino lining in my 02 Z71 and it is great no bad words here i had the dealer take it down and have it sprayed in as part of the deal so it has been close to 3 years now and still looks and works great. dont know the price of the line X but unless it is just a great price i would go with the rhino liner.....just my opinion.
Old 12-22-2004, 02:38 PM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Their both great, But i got the line-X because it seemed to have more grit to it. Dident seem like things would slide around as much...and they dont.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 12-22-2004, 05:58 PM
White Lightening's Avatar
White Lightening White Lightening is offline
In talking to several dealers while test driving vehicles before my purchase this year, I found that several of the dealers (even as far as 45 miles away) choose to have it done at Line X.
I also was at the Line X place - and the Federal government has vehicles and other "items" LineXed because of its durability. In cutaway samples I've seen - the LineX coating is "baked" on about 1/8th of an inch think (that is thick, not lightweight). Also - it adheres uniformly to the surface rather than just "filling in the holes".
Personal opinion seeing both of them - I liked the LineX better than the Rhino because it was baked on and thick. It wasn't "going anywhere" - no tearing, cutting, or shifting. Vertical or horizontal surfaces are no sweat.
White Lightening
Old 12-23-2004, 12:56 AM
acbaer acbaer is offline
Line-X is the way to go.
Old 12-23-2004, 07:33 AM
MarineJAG's Avatar
Wow! Thanks for all the advice! I think that I will be going with the Line-X. The "baked on" aspect seems to have a lot of apeal. Whan I looked around on line for other info a lot of sites mentioned that the baked on application vs. the cold application (Rhino) makes for a thicker coverage on the walls of the truck bed. Again, thanks for all the advice!
Have a Merry Christmas!
WILLIAM
Old 12-23-2004, 08:01 AM
Nigel215's Avatar
Yea, I read about that too. Line-X is used on army trucks on the floors and stuff. And I think the Navy uses it on the decks of some of thoes little crazy platoon boats. So that tells you it still works under wet conditions.
Old 12-24-2004, 03:35 AM
emmitt69's Avatar
emmitt69 emmitt69 is offline
I'm in the navy and yes they use line-x on the patrol boats we drive so we don't have to worry about slipping when we take on high wakes or high speed turns.
Old 12-24-2004, 03:22 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Around my area Line-x is top dog. I never knew that Line-X was baked on, I hadn't heard that before.
But, the quality of the liner also depends on your installer. If the truck isn't 'prepped' properly, the liner will not adhere and that will cause problems down the road.
I have seen some very sloppy applications of Rhino liners, again that is an installer problem, not a problem with the product.
Before having a bedliner installed, ask for the names of previous customers so you can ask them about their experience with the installer and also see the quality of the install. However, be aware that if the truck isn't 'prepped' properly, it could take years for a problem to show up.
Good luck with your liner and have a great holiday,
slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 01-10-2005, 07:59 PM
Jsilverado02 Jsilverado02 is offline
Just for giggles, I had two trucks done. One with the Rhino lining and one with the Line-X. As for durability. I have had better luck with the Rhino lining. If slipping was my only concern, then the Line-X. I haul everything from block to engines. My Rhino liner in my main truck is 1/4" thick. It seems to take impact loads far better than the Line-X. Good luck in whatever you choose.
Old 01-10-2005, 08:30 PM
ctimmons ctimmons is offline
I have the Line-X. 03 ext cab. First thing I put on the truck. Hauled everything and anything with no problems. It does seem to have a rougher surface than the Rhino liner. This can be good and bad. Good - less slippage. Bad - It is a pain if you get someghing like concrete dust in the surface. It will come out and will not stain, but it takes some work. According to my installer Line-X will be repaired by any authorized dealer no matter where you are and the only thing he knows that will stain the liner is deer blood. I think either will serve the purpose, you just need to decide rough - Line-X, smoother -Rhino.
Old 01-11-2005, 10:07 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
I have a drop in mat and it works plenty fine for me. dont forget the main purpose of spray on liners is to seal and protect the bed. my rubber mat cost $80 and nothing ever slides around in my bed. i personally would go with the rhino lining cuz like some one said its a pain in that ass to get stain or dust out of the gritty Line-X. Really i see no nothing better in grip between the two, yes Line-X has more grit for wet situation but either way nothing will slide on either, and its just a truck bed and not a navy patrol boat so it really doesnt matter.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 01-12-2005, 02:42 AM
main problem with drop ins and mats: is that water gets trapped underneath and if you don't address it you will rust holes through the bed floor and in the case of drop ins possibly the sides and especially at the corners of the wheel wells.
Old 01-12-2005, 07:23 AM
yeh i know but for my truck it was too late for all that cuz it was used to haul a bed camper before i owened it so it's pretty scratched up. but the point i was tryin to make is no matter what you buy, so long as its not a plastic liner, will protect the bed and nothing will slide around if its a mat, rhino, or line-x.
HD chassis package
