Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-22-2004, 11:25 AM
Mark Richards Mark Richards is offline
Angry 95 mustang GT with noisy clutch
My GT has 92K on its original clutch (not abused however) and it is starting to make a noise when it is cold and the clutch peddle is depressed. Does anyone know what is going on - throwout berrings? Is this something to worry about? I just don't want to be stranded on some back road with no clutch. I have also had to recently replace the front tie rods (squeeking) and the rear anti sway bar just broke. Is this what happens to Mustangs as they approach old age? What will go next??
Old 12-22-2004, 12:12 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: 95 mustang GT with noisy clutch
All normal SN95 problems. The idler pulley on the belt will probably go soon, too.
The squeal is your throwout bearing. Plan on a clutch job sometime soon.
The rear swaybars in '94-95 had a bad run of metal and were hollow to save weight. The factory control arm design doesn't help either, it allows the rear end to walk side-side some. Either switch to aftermarket lower control arms and/or get a '96-newer swaybar.
Front tie rods get noisy and need replaced. The new ones should have grease fittings and if maintained won't be a problem.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 01-16-2005, 01:31 PM
plateinum plateinum is offline
Banned
throwout bearing
is the throwout bearing and the release bearing the same thing or different
