Old 12-22-2004, 08:35 AM
metallica21156's Avatar
metallica21156 metallica21156 is offline
interior panels 95 blaz
i have a 95 blazer and i'd like to know if anybody know how to and the steps to remove the back panels to remover the rear speakers to replace them. its a 2dr.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 12-22-2004, 10:48 PM
swalt's Avatar
swalt swalt is offline
I couldn't find the removal procedure for the 2 door 95. Closest I could find was for the 2000 2door. GM's descriptions are a little lame though.
Trim Panel Replacement - Body Side 2-Door Utility
Removal Procedure
Remove the upper and lower front seat anchor bolts.
Remove the rear seat belt lower anchor nut.
Remove the assist handle.
Remove the coat hook.
Remove the endgate or the liftgate opening door sill trim plate.
Fold the rear seats down.
Remove the jack storage cover (left side only).
Remove the screw that retains the upper body side trim body side trim panel to the vehicle (left side only).
Remove the upper body side trim panel from the vehicle.
Feed the seat belt through the trim panel.
Remove the body side front lower trim panel from the vehicle
Old 12-23-2004, 03:17 AM
Re: interior panels 95 blaz
how do you get the caps off the assist handle? i could get them off to get to the bolts under them.
Old 12-23-2004, 08:32 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This is known to be a nightmare for stereo systems installers.
They hate 2wd blazers because of this reason.
I suggest cutting the area open and removing the stock grill and using the grill assembly that comes with the speaker to cover the hole.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-23-2004, 09:40 PM
sounds like more work to me. i'll see if i can't talk to a body guy to tell me how to do it. i might just stress the panel and use a ratchet to pull the bolts out. thats how i did the front doors.i never could get the panel all of the way off so i just stressed it and got it to work.
Old 12-23-2004, 09:43 PM
BlazerLT's Avatar
AF -Advisor
No it is NOT more work to leave the panel in place and cut a while around the existing speaker and use the speaker grill that comes with the speaker to cover the whole once the speaker is installed.
Why do you think a body shop would know about interior work?
Old 12-24-2004, 07:20 AM
because the've most likely have replaced it or pulled it off to fix it from being dented. i'll play with it so and see if i can't pull it off.
Old 12-24-2004, 08:35 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: interior panels 95 blaz
You are kidding right?
Old 12-24-2004, 09:01 AM
BlazerLT's Avatar
AF -Advisor
You have a 2 door blazer right?
Old 12-24-2004, 10:54 AM
yes
