Old 12-22-2004, 04:54 AM
Eagle086 Eagle086 is offline
Question O2 sensor bad?
Hi
I own a 1996 2.2 L Cavalier (no a/c), anyway, I've been having problems with very high fuel mileage and alot of bucking/vibrating at idol. Also all plugs are getting fouled and tip of tail pipe is black, and I am smelling gas on the oil dipstick. I've been researching and it seems like it's a bad 02 sensor. Does anyone concur/disagree. Any feedback would be appreciated. Also any other ideas as to what the problem might be. By the way I recently replaced 2 fuel injectors and the oil pan, fuel filter, air filter and plugs.
Old 12-22-2004, 01:43 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: O2 sensor bad?
Bad O2 sensor will cause you car to run rich yes... There are 2 of them that talk with one another and constantly change the mix every second your car is on... The one located on your header is the primary one that controls the A/F ratio but both are needed.. Also you car might be mis-firing so you might want to check and see if you have bad wires or Coils.. g'luck
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 12-26-2004, 06:06 PM
gonzales7727's Avatar
gonzales7727 gonzales7727 is offline
Re: O2 sensor bad?
o2 sensor is your problem, u should have three check the one after the cat
Old 12-26-2004, 10:12 PM
Lifted GMT-360!
Re: Re: O2 sensor bad?
NO...^^^^ there are only 2. OBD II have 2 O2 sensors.. OBD I have only 1...
