Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-21-2004, 11:48 PM
pierceS pierceS is offline
’90 4runner ATF Warning Light
90 v6 sr5, 155k miles; recently both the battery light and the ATF Warning Light came on at the same time. I pulled over and read the manual, which says the fluid is overheating and to shift into park and let it cool down. I did and it went out. Shortly thereafter it came on again but I was able to drive it home.
The last couple morning have been 38 degrees; I started the car and again both the ATF Warning Light and the Battery light came on again. Thus I know it is not is not because it is overheating. I checked the ATF level and it appears full.
I drove the car with the light on and it went out after a bit; a few minutes later it came on again.
Any suggestions as to what is wrong.
Old 12-22-2004, 08:22 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
Re: ’90 4runner ATF Warning Light
Try changing ATF fluid. It could be old which would effect the cooling capabilities. Just a suggestion. I don't know why it would come on in 38 degree weather. Good luck.
WAR UTAH!!
Old 12-22-2004, 11:37 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I bet it's your alternator. Have it checked.
