Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 12-21-2004, 11:32 PM
jdedgewood jdedgewood is offline
Question intake noise (growl)
My 2000 GLS automatic has a fairly loud growling sound when accellerating, sounds like it is the intake. Is this a normal noise, or something that should be investigated?
Old 12-22-2004, 01:13 PM
jettaboy jettaboy is offline
what engine you got? and is everything stock (OEM)?
Old 12-22-2004, 05:16 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
If you have a VR6, they do make that kinda noise when accellerating. It might also be the air change over valve in the intake.
Old 12-26-2004, 01:22 PM
Re: intake noise (growl)
It has a 2.0 engine, and the only thing about the engine that isn't stock is the foam airfilter. It sounded the same before I put the airfilter on it. It is low, throaty sound.
Old 12-27-2004, 08:48 PM
To answer your question, No thats not a normal sound from a 2.0L unless you have aftermarket intake. but if its not affecting gas mileage then I wouldnt worry!
Old 12-30-2004, 09:13 PM
No, I am getting around 29-30 MPG highway, so it isn't hurting the mileage.
Old 01-08-2005, 01:07 PM
pissboy's Avatar
pissboy pissboy is offline
check your header pipe mine cracked where they joined.
its not that bad to change if you have jack stands or ramps.
