Old 12-21-2004, 11:28 PM
d4h8a1's Avatar
d4h8a1 d4h8a1 is offline
Send a message via Yahoo to d4h8a1
Differential swap?
I am rebuilding an '88 CRX Si from the frame up. Recently I've started rebuilding the tranny. What I have is so worn out its amazing the thing went into any gear before I got it (I've never driven it). What I need to know is if there is any way i could possibly come up with a differential - from a '97 Prelude for example - that would help out with the overly simple stock diff. Am I an idiot for thinking something like that?
Old 12-21-2004, 11:32 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Differential swap?
nope you need a differental from a 88 si only. Im not sure but 89-91 ones might work also!
Old 12-21-2004, 11:33 PM
d4h8a1's Avatar
Re: Re: Differential swap?
whats the difference between the stock transmissions that came on this gen. of cars? How can you tell between them?
Old 12-21-2004, 11:53 PM
the transmission has a different number of splines on the input shaft. 88 trannys are different from 89-91!
Old 12-22-2004, 09:06 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
the input shaft size is different. thats the only difference that matters.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-22-2004, 11:14 PM
d4h8a1's Avatar
Where would the best place be to find out everything there is to know about these trannys ? And where can you get any of the special tools to work on them ?
Old 12-22-2004, 11:23 PM
EF You's Avatar
EF Life Giver
i tore down a few of them, i didnt use any special tools. i mean, there may be special tools that allow you to assemble it easier, but i did just fine with hand tools and a feeler gauge
Old 12-22-2004, 11:27 PM
d4h8a1's Avatar
Except for the bearings, you have to use a press, right ?
