Headlight Sensor
Hello,
I'm new to the Grand Prix forum and wanted to see if anyone new the answer to this question. I have a 2000 GP which came stock with daytime headlights which I didn't like so I found out how to pull the plug next to the sterring colum to solve that problem. My question lies with the sensor that automaticlly turns my headlights on at dusk when I would prefer to run just my fog lights until it gets dark. Does anyone (if it can be done) know how to disconnect that sensor? Thank you!! Steve Shannon |
Re: Headlight Sensor
Hi Kustomkid54,
Thank you for the info regarding the Daytime Running Lights. I acually disconnected those a few months ago. The problem I'm having, is the headlights turn themselves on automatically when it gets dark outside when I would prefer to run my fog lights only. The headlights are off all day until dark. How do I stop them from coming by themselves at dark without me turning them on? Thank you!! Steve (ssfastgp) |
Re: Re: Headlight Sensor
www.easyperformance.com then go to products and then GM Headlight sens. not sure how it installs or how much it costs. you could ask [email protected] and see if zzperformance.com or any1 else sells it. hope this helps ~Matt
'99 SE (l36) 125k mi. FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Morning blurr
GM is talking about removing the wire from the sensor in dash. I have never tried that, I like the lights to come on when it gets dark. You could wire a switch to the sensor and turn it off. That way you still have it in line if you ever want it. May want to get with Big-L, Cass or GTPDAD. Big-L because he can find anything. Cass, because he more then likely has tried it. And DAD because he has the information at hand from GM.
Thanks guys for the info. That gives me a place
to start. Steve (ssfastgp) |
short the sensor wires on the light sensor and the headlights will stay off, however thats one of the tightest features so I suggest rather than disabling it, just drill the hole bigger so the sensor takes longer to trip...
http://members.cardomain.com/empathydude Put an extra set of neon lights on your car, they make you go faster. =) |
Hey Empathydude,
My weakness while fixing up my car is anything that requires me to rewire something so I don't want to do anything that's going to damage it. Out of all the suggestions I've received yours regarding the shorting out of the wire or drilling the hole bigger sounds like the easiest. Can you tell me briefly where it is and how to do it? Thank you!! SSFASTGP |
hey guys i have a 97 and all i did was pull the drl fuse and now the auto headlights dont come on.u have to use the headlight switch all time.ha ha
DarkTint 1999 Grand Prix GT 2-Door 2008 Honda CBR600RR |
If you turn on parking lights, fog lights will come on. But as you send, when it's dark headlights will also come on. GM says wire has to be removed. Have never tried it, but that's GM
Just so everyone knows, this post is not about daytime running lights and how to deactivate them. Those of us that want that look have already "pulled the plug." It's about the next step regarding the sensor that automattically turns your OFF headlights ON at dusk and how to deactivate it. Responding to the previous post, who out there has been brave enough to pull that wire? I know somebody's done it and been successful or crashed and burned. You could really help out your fellow GP owners if you would let us know either way.
DarkTint Rocks!
With all of the comments I received regarding the deactivation of theautomatic headlight sensor, I was glad to see a simple suggestion that sounded to good to be true. I tried what DarkTint suggested about turning the headlight switch between the parking lights and the headlights and that allows you to run just your fog lights with no headlights as long as you want too. It works-----Try it-----Thanks again!! |
