Old 12-21-2004, 09:46 PM
jcmmako jcmmako is offline
accord key and sport shift problem
Hello.....I have a 90 accord (mint with 100 000 miles) so I do not want to part with it. I have trouble removing the key. Often when shifting into park, the red light will not activate right away and so the key is stuck until this light goes on....anywhere from 30 sec to a few minutes depending how cold it is. Just this week, the sport shift is stuck. The button goes in and out but the car will not kick into the higher gear. Any suggestions please! different problems or related to the same issue?
Old 12-21-2004, 10:26 PM
mpumas mpumas is offline
Re: accord key and sport shift problem
First problem is a dirty gear shift selector switch which is located on the center console to the left of the selector. Remove the cover by removing the four screws and you will see the switch. It is made of white plastic. You can disassemble the switch without removing it. Clean the contacts, grease lightly and reassemble. The second issue has been addressed in other posts on this board.
Old 12-21-2004, 10:45 PM
AccordCodger AccordCodger is offline
Wow, somebody who actually CARES about the sport shift!?
Old 12-22-2004, 11:12 AM
sport shift
I never touch the sport shift because I think it is a waste...but a friend drove my car and used it....now I care because the when this is engaged, the engine will not shift into high gear.
Old 12-22-2004, 11:56 PM
"The light displays a problem with the TCU or a sensor that feeds the TCU.
