Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 12-21-2004, 09:30 PM
Jelly JoJo Jelly JoJo is offline
Send a message via AIM to Jelly JoJo
debating whether or not to buy this prelude...NEED INPUT!
I am thinking about buying a 95 Prelude SE with 157k..the timing belt needs to be replaced...it has the 2.3 DOHC. was wondering what it takes for a timing belt to break on a car...checked car fax and it has a clean history. any input would be great.
Old 12-21-2004, 09:39 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Re: debating whether or not to buy this prelude...NEED INPUT!
the timing belt is not on there, or is it just going to break soon. A timing belt breaks when it gets worn out. If the timing belt is already broking it's a gamble.
John 3:3
Jesus answered and said to him, "Truly, truly, I say to you, unless one is born again he cannot see the kingdom of God."
Old 12-21-2004, 11:45 PM
ludeguy ludeguy is offline
Re: Re: debating whether or not to buy this prelude...NEED INPUT!
yah i agree... if the car is sitting there, and hasn't moved because it broke a timing belt - I wouldn't touch it. If it currently has a timing belt but the owner is cautioning you to get it replaced - you are in for a pretty big bill right off the get go (unless you are mechanically inclined), and the belts aren't too cheap either. Although I would always recommend anyone buying any second hand lude to put a timing belt change on their agenda of things to do.
Old 12-22-2004, 02:07 AM
boytiti's Avatar
boytiti boytiti is offline
my 93 prelude has 185K miles and I havent replaced the timing belt yet. I am getting ready to replace it soon.
My WebSite
Old 12-22-2004, 09:59 AM
PoorLuder PoorLuder is offline
The timing belt replacement could also lead to your first upgrade if you replace everything with the AEM pulley set. I changed my timing belt a little while back and could kick myself for overlooking this upgrade. Anyway, back to your question about the belts. Normally you should replace them around 80-90k range. Several other related components such as the water pump may also be replaced. I think my bill for getting it done at Pepboys was in the $500 range. I would ask the seller to lower his price (if he hasn't already) and to take the belt work into consideration. By the way, how much was he asking for?
Old 12-22-2004, 10:32 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
The guy's timing belt should have been replaced at around 90k, when his first major tune up (plugs, wires, cap, rotor, filters, pumps, fluid flushes, etc..) should have been done. Ask him when's the last time the car has been serviced.
I wouldn't worry too much about it, since he's already telling you off the bat what the car needs, instead of trying to hustle you with a car that's seemingly perfectly fine.
I doubt the belt is on the verge of breaking or anything. But perhaps you can strike a deal with him; have him replace the belt, and give the car a minor tune up, and you pay a bit extra. Or maybe you can get him to lower the price a bit, and the first thing you do is take it to the shop for a quick tune up.
Old 12-22-2004, 11:51 AM
SBallerk2 SBallerk2 is offline
Send a message via MSN to SBallerk2
"boytiti" damn dude that's one SICK!! PRELUDE!!
PRELUDE's
Old 12-22-2004, 06:58 PM
only 1500, crazy right?!?
Old 12-22-2004, 08:55 PM
hell even if it has a blown engine 1500 is good - if it's body is toight and it hasn't been in (m)any knockups (: you could part that thing out for way more than that even if it doesn't run.
Old 12-23-2004, 02:22 PM
joellthomas joellthomas is offline
Is the belt already broken or just needs replacing. If ist's already broken subtract $1500 from it's value.
Old 12-23-2004, 03:45 PM
Price does seem really low but that should only mean that you look at it that much closer. Did you find the car on cars.com or autotrader? If so, could you post the link so we can get a better feel for the car. Also, please tell us if the belt broke or not.
