Old 12-21-2004, 09:12 PM
aking3000gt aking3000gt is offline
Send a message via AIM to aking3000gt Send a message via Yahoo to aking3000gt
Motor Mounts
I'm currently looking into buying Motor mounts for my 3kgt.... but does anyone kno the benifits and if its worth the time and money????
1994 3000GT VR4 Pearl Yellow
1994 3000GT Base Pearl White
Check out my Cardomain Website!!!http://www.cardomain.com/memberpage/800196
Old 12-21-2004, 09:52 PM
G35turbo G35turbo is offline
Re: Motor Mounts
it dependes how strong your engine is. IF you engine moves around beacue of to much power,then i guess it would be a good time put motor monts. But i dont now much about this subject.
If you go to 3sxperformance.com they have a video clip that would answer your question.
Old 12-22-2004, 10:45 AM
stfuad's Avatar
stfuad stfuad is offline
Send a message via AIM to stfuad
Re: Motor Mounts
Motor mounts == less engine movement, which == less chances of stuff snapping if they're rusted. Common stuff is exhaust pipes and stuff... <- First hand experiance...
The downside to polyurethene mounts, would be a slight increase in idle vibration.
Old 12-22-2004, 12:00 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
motor mounts are very important, a degenarated motor mount will shake the car lightly and cause an uncomfortable ride and can even affect your speed. a really bad motor mount will break old hoses, fittings and anything else that is worn out just like stfaud said. the most common thing that bad motor mounts do is snap your shift cables, the cables that go from your shift knob to the tranny, shake a motor hard enought and "snap" your stuck in third gear!
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 12-22-2004, 12:04 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
lookin to get some motor mounts, huh? i've heard they're awesome...we should all get some!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-23-2004, 12:36 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Motor Mounts
They also seem to help the transfer case, if your engine can move enough the transfer case will slam into the crossmember under the car.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-23-2004, 07:42 AM
stfuad's Avatar
Re: Motor Mounts
Too bad about the core charge for the 3sx motor mounts, $650 is kinda stretching it for me.Even knowing your getting the money back it's kinda like taking it up the ass.
Old 12-23-2004, 07:17 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Motor Mounts
I have never heard of anyone snapping shifter cables because of a bad mount. I had a bad rear mount for almost a year and the only extra carnage caused was a busted downpipe. On another note, stock mounts suck. If you do any kind of racing, drag strip, auto x, etc mounts will help you.
Old 12-23-2004, 08:29 PM
Re: Motor Mounts
You can get solid steel ones from maximal preformance, something like 250-300 and no core charge.
