Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-21-2004, 08:26 PM
stoneclad1 stoneclad1 is offline
1991 S15 will crank, but will not start
OK, son's vehicle. Would not start at girlfriends, towed home. Has replaced fuel pump & filter, coil, ignition module. At this point it started and ran better than ever before (bought in June of 04). He drove it around the block and parked it. Will not start again.
Help Pete
Old 12-22-2004, 03:56 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1991 S15 will crank, but will not start
Checked fuel pressure?
Ever replaced the fuel filter, new plugs, cap and rotor?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-22-2004, 09:34 AM
All ignition parts are new, with fuel line disconnected on the motor side of the filter, fuel gushed out when the motor was cranked.
Old 12-22-2004, 12:25 PM
BlazerLT's Avatar
AF -Advisor
How is the timing?
Have you timed it with a timing gun with the timing wire disconnected from the PCM under the glove box.
The timing will go out over time and mile and has to be set to base zero every 3-5 years.
Old 12-22-2004, 12:53 PM
PCM? My other car is a '69 Camaro. I don't know what all this other stuff is. Which one is it? There's a ton of wires under the glovebox. Thanks.
Old 12-22-2004, 01:13 PM
BlazerLT's Avatar
AF -Advisor
it is a brown and beige wire that runs under the carpet.
It has to be connected to properly time with a timing gun.
Old 12-22-2004, 01:19 PM
Connected? I thought you said it had to be disconnected. I found it, now what?
Old 12-22-2004, 01:20 PM
BlazerLT's Avatar
AF -Advisor
oops, typo, I meant disconnected.
With it unattached, time the vehicle with a timing gun and set it to zero.
Old 12-22-2004, 01:25 PM
How do I set the timing if the motor doesn't run?
