Old 12-21-2004, 08:20 PM
Ukrainianstud1900 Ukrainianstud1900 is offline
trans question
HI there, I have a question regarding tsi trannies. Is it possible to turn off awd and switch to rwd in talons 90-95? thanks
Old 12-22-2004, 01:51 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
I've heard of many people taking out the driveshaft and converting their car into a FWD, although you take a loss in power doing that.
However... you want your car to be RWD? Why would you wanna do that? Especially if you have a well sought after AWD? Sounds like a new tranny to me. Good luck finding one that bolts up. STAY BEAUTIFUL! STAY AWD!
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 12-22-2004, 02:02 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: trans question
There is info on this site about this already, its not worth the effort. If it's for a purpose built drag-only car, the right thing to do is to rotate the motor 90 degrees and adapt a 2 speed powerglide transmission. 9" rear ends, customs suspension, custom driveshaft, etc, are common items that go along with this conversion.
To do it in our tranny you need to lock the center diff with a welded diff, spool, welded VC, or VC eliminator. By removing the tcase you have FWD (common for 2WD dyno use), and by removing the front axles (but still blocking the holes in the tranny) you get RWD. But the RWD components were only meant to take a portion of the torque output, not 100% of it. You run a pretty good risk of douching the t-case or rear axles.
Edit> And yeah, AWD is the tits. I can't think of a good reason to switch.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
