4wd switch problem
switch lights up momentarily when key is turned on. no lights or sound at all when pushed
I tested fuse OK .tried to disconect battery no help .Change switch module from different jimmy same .My switch work on other car ,so I pyt it back Any advice on what I should do next? Thanks! |
Re: 4wd switch problem
Check the 4x4 switch relay.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Transfer Case Module...they are defective on this trucks. See MSN Auto's Reliability Ratings.
This is not switch relay .
I tested T/case Shift Control module -it`s deffective 305$ from the GM Easy to replase ,take the buttom passanger side panel (no tools needed) you will see module #15741322 Thanks JimmyGold |
Hey Sergeia,
PLEASE DO NOT GET IT FROM GM! GO TO GMPARTSDIRECT.COM!!! They have it for $174. That's where I got mine last year. Or you can try a junkyard if you want a cheap used one. Install is EASY! |
I get it from ebay for 70$
Thanks |
