Old 12-21-2004, 06:49 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
EFI fuse, i need a map asap!
i need to know what fuse is the efi fuse and or can someone give me a map of the fuses under the hood. my map is gone
i need this asap and will highly appreciate it.
i need to cut off the fuel so i can run a compression test.
Old 12-22-2004, 02:36 AM
youngvr4's Avatar
STREET RACING GURU
Re: EFI fuse, i need a map asap!
bump
Old 12-22-2004, 02:39 AM
GritMaster GritMaster is offline
Does http://www.stealth316.com Have it? I'm too lazy to look right now :P
Dunno if you already tryed looking there/
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 12-22-2004, 11:16 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
edit: They do have a map at stealth316 http://www.stealth316.com/2-diagconn.htm
Resistance Is Futile (If < 1ohm)
Old 12-22-2004, 12:30 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
need to cut off the fuel? go to stealth316.com, follow the instructions for changing/upgrading the fuel filter. in that procedure, you cut the fuel flow by unplugging the electrical connection on the fuel pump, then you try to start the car in order to relieve the fuel pressure in the lines.
bonne chance!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-22-2004, 05:55 PM
youngvr4's Avatar
STREET RACING GURU
i need the one for the outside fuses
Old 12-23-2004, 02:40 AM
BB1970's Avatar
BB1970 BB1970 is offline
im at work right now young, but can look later for you at home. im pretty sure ive got that info there.
will be home just after 6pm uk time.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 12-23-2004, 12:46 PM
youngvr4's Avatar
STREET RACING GURU
thanks
Old 12-30-2004, 09:20 AM
BB1970's Avatar
dude sorry not been in touch but cant find that info anywhere but thought you can pull the fuel pump relay which is behind under the fuse box and it wont pump then anyway.
hope it helps
bb
blitz dome filter
sachs clutch
