Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-21-2004, 06:30 PM
vin007 vin007 is offline
92 Cutlass Supreme 3.1 won't start
my cutlass keeps dying after you drive it for roughly 15 minutes, it stauls then allows a couple of restarts but then it wont respond after it dies for last time. The starter is ok the spark plugs are fine and we replaced the ignition module and fuel filter and everything else checks out. It seems like the fuel pump isnt "pumping"..any ideas?
could it be any heat sensors or stuff?
Old 08-08-2005, 01:28 AM
OldzCutlass90 OldzCutlass90 is offline
Send a message via MSN to OldzCutlass90
maybe you need a new fuel pump? did u check to see if it pumps it up to the fuel rail? and try to squirt it see if it comes out????
Old 09-20-2005, 03:34 PM
Fehrasarx65 Fehrasarx65 is offline
Talking similar common problem
I have a 92 pontiac grand am that had a similar problem. There is a sensor called a tcc sensor on the front of the tranny. When it goes out the car will run for aboiut that time or 5-15 miles and then dies. You can disconect it to do oround town driving and it wont die. It will need replaced as soon as possable though. In which case you can do it yourself. Just try it first, if it works then there you go, if not then sorry thats all I got.
