Old 12-21-2004, 05:45 PM
Iluvmytsi Iluvmytsi is offline
I Need Maf Help Asap!
I need to know if the mass air flow sensor plug on a 95-99 eclipse/talon turbo is the same as a n/t. I need to buy one of the plugs to make my turbo maf work but the only one I can find is for a n/t, will this work? I need help ASAP, Thanks!
Old 12-21-2004, 06:10 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: I Need Maf Help Asap!
doubt it.
Old 12-21-2004, 07:05 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
check dsmtrader for someone parting out a turbo 2g. or call all the local junkyards
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-22-2004, 02:32 PM
kjewer1 kjewer1 is offline
AF - Advisor
I believe the 1G NTs use the same sensor as the turbo cars, someone correct me if I'm wrong though. The 2Gs are certainly different though.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-22-2004, 04:33 PM
1g mas plugs are all the same i can say so from experience.
-1stGenRocks-
