Old 12-21-2004, 05:05 PM
DJCintheROC's Avatar
DJCintheROC DJCintheROC is offline
Send a message via AIM to DJCintheROC Send a message via Yahoo to DJCintheROC
1995 Blazer with a few problems
ok,i have a 95 Blazer, i have a few problems,
- code ph1509
-idle rough when cold, then when gets warms it idles rigt
-what is CPI mean
-my heater/a/c vent is stuck on the defogger, it olny blows out of the defogger, it's does nothing when i switch to vent , heater, etc, i hear a click but idk what it wrong with it
Old 12-21-2004, 06:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1995 Blazer with a few problems
Code 1509 is for the IAC valve.
Remove the Idle Air Control valve, clean it with TB cleaner and scrub it lightly with a toothbrush and then reinstall it.
Have you done a tuneup lately?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-21-2004, 06:58 PM
teddybear8203 teddybear8203 is offline
Jack of all Trades
the controls are ran off vaccum.. i had the same problem and my vaccum hose was disconnected from the vaccum resivour that is mounted to the hood...you have to look for a vaccum leak somewhere...
Old 12-21-2004, 07:02 PM
BlazerLT's Avatar
AF -Advisor
The vacuum ball on the drivers side portion of the engine bay near the windshiel is where to start.
Old 12-21-2004, 07:53 PM
Ok, no tune up but i just bought the truck, like 3 weeks ago from a bootleg dealer,I also took one spark plug out to see how the engine is runnin and it's runnin clean, the plug was like new, i bought a new IAC and still the same code, it says it has a short in the circuit, where's the cicuit idk, and hmm the vacumm i will check on that tomorrow asap when i get home from work
Old 12-21-2004, 08:11 PM
BlazerLT's Avatar
AF -Advisor
It could because you have a vacuum leak and the IAC can not compensate for it.
Remove the negative battery cable for ten minutes, start up the vehicle let it warm up and then hold the brake and put it in gear for two minutes and don't let the truck move.
This will force the computer to relearn the idle.
Old 12-21-2004, 08:16 PM
hmmm, wow sounds good i will try that, wow i notice you know alot bought the blazer
Old 12-21-2004, 08:20 PM
alot about* the a Blazer
Old 12-21-2004, 08:22 PM
BlazerLT's Avatar
AF -Advisor
It sall good, I try to help everyone.
I would seriously consider tuning up the truck.
Consider everything was never touched.
Plugs
Wires (might not have to replace)
Cap & Rotor
Fuel Filter
PCV Valve
Air Filter
Old 12-22-2004, 03:21 PM
scdog scdog is offline
What is a TB cleaner? Where is the IAC located?
Old 12-22-2004, 04:33 PM
tb cleaner is THROTTLE BODY CLEANER (SAME AS CARBERATER CLEANER) AND THE ICA IS LOCATED ON THE TOP OF THE ENGINE, TO THE RIGHT OF THE THROTTLE POSITION SENSOR
Old 12-22-2004, 04:34 PM
-what is CPI mean
Old 12-22-2004, 11:52 PM
BlazerLT's Avatar
AF -Advisor
Central Port Injection
Old 12-23-2004, 08:09 AM
Re: Re: 1995 Blazer with a few problems
thanks
Old 12-24-2004, 08:08 PM
o hey i meant the left of the throttle position senser
