Old 12-21-2004, 03:49 PM
barteldt barteldt is offline
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
Question diffrent distrubutor
im putting a new jdm in my 93 metro everything seems the same but the distrubitor is diffrent my old one had no vacuum advance but the new one is a diffrent size .will the vacuum advance type that came on the engine work in this car . my brother in law says he can mill out the other distrubotor to get the bolts to fit if we need to. anyone else had this problem let me know
Old 12-21-2004, 11:40 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: diffrent distrubutor
you will want to reuse your old distributor, the vacuum advance one will not work right with your computer. you might have to change the bracket that the distributor fits into, it is held on with three bolts. usually they are the same bracket, are you sure you don't have the distributor body 180% out? try spinning it halfway around
Old 12-23-2004, 01:36 AM
RossT RossT is offline
I just did the JDM into my 91 metro about 2 months ago. You will have to use the old Dist. like the above poster said to do. Also the JDM in Japan are carbed and that old Dist. is nothing like the ones over here.
The only things that you can really use from the JDM are the head and complete block. It's also a good idea to replace ALL the gaskets (including the head gasket)!! Everything else comes from the old engine.
I even tried to use the JDM belt pullies cause they looked so good. Found out that they line up differntly.
E-mail me if you have questions.
Mine works really well
Old 12-23-2004, 06:04 AM
Crvett69's Avatar
if the new engine came with the alternator you can use the pulleys on the engine if you also use the jdm alternator. if it did not come with alternator you will have to swap the pulleys over
Tominator2000 Tominator2000 is offline
I changed the distributor and valve cover on my jdm swap.
The crankshaft pully works fine on my non-ac car.
That's all that was done other than new valve cover and manifold gaskets. Started right up! Gets 40+ mpg and uses absolutely no oil!
