Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-21-2004, 02:49 PM
winstonusmc's Avatar
winstonusmc winstonusmc is offline
SAFC with larger injectors
Does anyone know if a SAFC works good with upgraded injectors. I am planning on uprading to 550cc injectors. I know I can tune it but the question is will the timing be OK? Messing with the air flow signal scews with the timing. And on turbo engines, timing is important. I want to know because I am too cheap to buy a JWT tuned ECU or a power FC. But if I cant do it with the SAFC, I will break down and buy the Power FC. Also, does anyone know how the stock boost controller on the redtop works? I know the Power FC will adjust the stock boost controller, but I dont have one. I am looking for one if anyone has one.
SR20DET RPS13
3" Trust Downpipe, Catco Cat, RS*R ExmagII Catback
Z32 Brakes, Tomei Technical Traxx LSD
Blitz BOV
Old 12-21-2004, 03:15 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: SAFC with larger injectors
ut oh the marines have invaded...no just kidding...where are you located at marine? (i know off subject) and as far as i know the SAFC is compadible with larger injectors...doubt that helps i guess
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 12-21-2004, 04:03 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
It does screw with the factory timing maps, but a lot of people use it with sucess. The SR ECU may react differently than the KA ECU, but people use the SAFC on the KA and just make sure base timing is correct. The SAFC II comes with a knock sensor display so you can monitor timing as well. I would advise a wideband as well because over time, the factory ECU slowly changes part-throttle maps back to the factory maps. Ergo you will be running lean one day at part throttle. If you have the money, go with the power FC or another stand-alone. Glad to see you came back okay. Thanks for going over there. Good luck.
BTW doesn't JWT have an SR ECU tune?
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 12-22-2004, 06:36 AM
To answer Driftking's question, I am still in Iraq. They just have a great internet cafe here. I am still here and dont return to Cali for another couple of months, then the mass of parts will be bought from the nice savings. Yes, JWT has an SR tuned ECU, but for that money I will buy a power FC on Ebay.
SR20DET RPS13
Blitz BOV
