Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-21-2004, 12:18 PM
cnilkyrclit cnilkyrclit is offline
1988 corolla
Ok, I Think The Pump For My Washer Fluid Is Bad. It Dosent Spray When I Press The Button Sometimes, And Other Times You Can Hear The Pump, But No Fluid. Or Nothing At All. I Would Like To Try Fix This Myself, Hwere Is The Pump And What Do I Have To Do Tto Fix It. 88 Corolla Sedan Please Help. also when i press the gas pedal the lights and blower seem to work better and hen when i come to a stop everything dimms out. any help would be greatly appreciated. i love this car, it runs good to be about16yrs old. only 106000 miles on it. and 1 more question, is it possible to put larger exhaust pipes and muffler to help increase airflow. i plan on getting a k&n air filter. just want to keep it simple. thanks.
Old 12-21-2004, 01:17 PM
racer_in_black racer_in_black is offline
Re: 1988 corolla
If everything is dimming out when you stop or slow down, it's going to be the alternator. Check the battery too.
Old 12-21-2004, 01:56 PM
toyota_fan toyota_fan is offline
For the washer, it may be your nozzles are corroded and clogged up. You can try to clean them with CLR calcium lime and rust cleaner. Or do the easy thing and go to the junkyard and get a different set. When you have them removed from the car, try to blow through them. If you can then they are good and clear. Got a replacement set for my 90 Rolla for $2.
Old 12-21-2004, 02:24 PM
Re: 1988 corolla
Thnk You Guys Very Much, I Was Just Thinking I Do Live In Cleveland, Oh. And Right Now The Weather Is Very Cold Here, They Could Just Be Frozen. (solution Frozen In The Nozzle May Be Frozen.)
