Old 12-21-2004, 11:40 AM
Yungstar007 Yungstar007 is offline
Send a message via MSN to Yungstar007
Gas mileage, is this normal?
What's going on guys, just wanted to get some feedback regarding the gas mileage I'm getting; to put it in short, it's pretty bad.
I fill up about 37 Litres and get about 320 Km (converts to 9.7 gallons and 198 miles respectively) with the gauge not too far from the empty line. It calculates to about 20 MPG.
Is this a normal range or is something possibly wrong? I figured I should be getting higher because 20 does seem quite low and the price of gas is not helping me out one bit. Someone mentioned me utilizing cruise control but I rarely use the highways anymore, if at all.
The car is completely stock, no mods whatsoever and I fill on premium 89 octane. It's a 98 TSI AWD by the way.
Any help would be great, thanks.
My ride:
1998 Eagle Talon TSI AWD - Standard
Old 12-21-2004, 12:01 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Gas mileage, is this normal?
Never put anything lower than 91 octane in your car!!! That would also explain the gas milage... And in fact your gas milage really isnt that bad. For town driving thats probably the most you will see. Always put 91+ octane in, if you cant afford it, you cant afford a turbo car so dont drive it unless you feel like replacing the motor when you melt your pistons!
Old 12-21-2004, 12:06 PM
GSTRacerNVUS GSTRacerNVUS is offline
Doesn't seem too wierd to me. 20mpg is probably about average for city driving.
Is 89 the highest octane that you can get? Premium here is 93.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 12-21-2004, 12:09 PM
91? The silly Mitsu dealers said 89 was perfectly fine to fill on and that the car as it was was filled on 89, what idiots. It has nothing with me no being able to afford 91, I was actually just going by what was told to me. They said as long as I wasn't filling on 87, it wouldn't be a problem as long as I put in 89, but 91 wasn't needed. Unbelievable.
Thanks for the response.
My ride:
Old 12-21-2004, 12:12 PM
NCTotalEclipse NCTotalEclipse is offline
Send a message via AIM to NCTotalEclipse
Doesn't higher octane fuel burn faster and cleaner? That's what I have always been told... but there are tons of people around here that are still oblivious to the fact that fuel injection has been invented.
Re: Re: Gas mileage, is this normal?
Yeah, a couple chains of gas stations carry the 93 octane, but they are aren't as near to me. The stations I frequent mainly carry 87 (Regular), then 89 and 91.
My ride:
Old 12-21-2004, 01:14 PM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
93 is the highest you can get, that sucks. Here in Pa i can get 94 and, like 5 miles from my house i can get 100. I always use 94 nothing eles unless im travling and they only have 93.l
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 12-21-2004, 01:17 PM
Andydg Andydg is offline
I wish I was getting 20mpg, I get around 16-18...
Old 12-21-2004, 01:26 PM
Sorry, 94 is also available at the same stations that carry 93.. 100 on the otherhand, that I have not seen, lol.
My ride:
Old 12-21-2004, 01:52 PM
george536's Avatar
george536 george536 is offline
the highest here is 91 at all the pumps, unless you want 100 for race gas.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 12-21-2004, 02:38 PM
There's a couple gas stations here with 100 and 104. I've never tried the 104, because its about $5 a gallon. I just seems a little high for not that much of a difference.
97 Eclipse GST MT
Old 12-21-2004, 02:55 PM
george536's Avatar
over here is $5 for 100 octane gallon
-1990 Eclipse GSX
Old 12-21-2004, 04:32 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
I can only get 91 here, it sucks. I get like 400km to a tank on my 94 usually and I havent exactly been driving it super nice :-)
"You can have everything in life you want if you will just help enough other people get what they want."
Old 12-21-2004, 05:51 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
94 is the highest i've seen here. to answer somebodys question. higher octane doesnt in itself give more horsepower. the octane rating is what determines how prone to knock it is. basicly higher octane allows you to run more boost before you start knocking and the computer cuts the boost and the timing
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-21-2004, 07:52 PM
EclipseRST's Avatar
Banned
It burns slower and cooler so you can boost more without seeing knock and detonation.
