Old 12-21-2004, 11:18 AM
decaturforlife01 decaturforlife01 is offline
Finding the right wire for remote start
I just got to the ing block and and tested all the wires. I have two wire that have a 12v reading when the car isn't in run or Start. The wire are located one is the first and last wire on the block. I have a that i cut and try to start the car and it will not turn over. I have in all 6 wire on the block. When i turn the key to run i get a reading on all the wire but two. But if it is in the start i get a reading on all of them. The alarm is a hornet 563t and is going on a 99 tahoe. By the way i just took off a alarm and hook the wire that they cut from the starter to starter wire on the new alarm.
Old 12-21-2004, 04:13 PM
jdl jdl is offline
Post
There is a site at www.the12volt.com that is an automotive electronics installers site, they have several forums for asking questions and alot of info on vehicle security systems and remote start, whatever. If you don't find an answer here that helps, try over there. goodluck
Old 12-21-2004, 05:53 PM
Thanx for the info
Old 12-21-2004, 10:03 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Finding the right wire for remote start
DUDE. Make sure to power both ignition wires. If not, the truck will start fine but the tranny will self destruct.
12volts red + ignition harness
Starter yellow or purple + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition white + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
Accessory orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue either door boot
Notes: The 4 door versions are positive trigger, and the 2 door versions are 5-wire.
Power Unlock white either door boot
Lock Motor gray drivers door boot
Unlock Motor tan drivers door boot
Parking Lights+ brown headlight switch
Notes: Also found low in the drivers kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger purple - headlight switch
Dome Supervision white - underdash light
Trunk/Hatch Pin tied with doors
Hood Pin
Trunk/Hatch Release black or blk/wht low in the drivers kick
Notes: Positive trigger on models with rear lift window, and 5 wire on models with cargo doors.
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white ECM
Notes: ECM is located on drivers side inner fender. Tach wire found in a black plug marked white.
Diesel wait to start wire is dk. blue (-) located at the instrument cluster.
Wait to start
Brake Wire white + at brake pedal switch
Parking Brake
Horn Trigger black - at column
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 12-22-2004, 06:45 AM
Thanx alot because last night I got it to turn but it will not start up because the fuel inj. was not getting power form the remote. I had hook up Red constant 12v, yellow for the starter and was trying to find the right connnect for the ignition 2 wire. On my book it read purple is the starter side wire, green is starter input keyside, red is 12v input, orange is acc, pink is primary ignition circuit, red is 12v input, pink/white is output to 2 ignition circuit, and red/white is high current 12v input.
