Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-21-2004, 11:11 AM
J_ROC812004 J_ROC812004 is offline
Send a message via Yahoo to J_ROC812004
Angry door hinges 95 t-bird
i was wondering if it is possible to change the hinge pins on my 95 or if i have to get whole new hinges. i went to auto sone and they said they sell hinge pins for the 95 t-bird but i went and had a estimate done at the shop and they said that they have to get whole new hinges anybody have any idea?
Old 12-21-2004, 04:05 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: door hinges 95 t-bird
You have to take the hinge out to see if it's worn to far to replace just the pins. It's usually just the lower hinges that need to be replaced. If you take the hinge out and find it's too worn to replace the pin then you have to reinstall it and remove it again when you get the new hinge. If you are short on money do it that way and hope for the best. I put a value on my time so just replaced the hinge and got it over with. They take time to replace but if you have a jack to support the door, a set of short 3/8 drive sockets, a flex adapter and a 6 inch extention you can do it yourself and use the money you would have paid the shop to do it to buy the hinge.
Old 12-22-2004, 12:44 AM
I went to the junk yard and i tried to take hindes off of a junk t-bird but i could not get them off, is there a special way to get them off?
Old 12-22-2004, 02:41 PM
97Bird's Avatar
For the lower hinge, open the door all the way and use the extention, flex adapter and short socket to remove the front two bolts. You have to remove the kick panel inside the car to get the back bolt's nut out from the inside. Be careful not to loose the nut down inside the panel or have a magnet ready. Don't waste your time taking hinges off of another car. It's a waste of time since they will be warn out usually as well. Bite the bullet and install a new one the first and last time!
Old 12-22-2004, 05:03 PM
alrighty do i have to take off any paneling on the inside of the car to get to the kick panel?
Old 12-22-2004, 08:07 PM
97Bird's Avatar
The kick panel IS what you remove from inside of the car. As you sit in the car it is the plastic panel to the left of your left foot! There is one screw holding it in place. Remove the screws from the scuff plate on the sill and lift it up. This is the piece that runs along the bottom of the door opening. It holds the carpet in place and also the back lip of the kick panel. By looking at the new hinge you should be able to judge where the bolt of the worn out hinge goes through the body. You may have to move some wires around that are in back of the kick panel so that you can reach in and feel the nut that you have to remove.
Old 12-23-2004, 12:45 AM
well ty i think i can go ahead and get this done now finally lol
