Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-21-2004, 09:50 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Wish Me Luck Guys.
I am going to begin installing some parts that I have been sitting on for a few weeks today.....I have the next few days off of work so I will be installing....
1) HKS 272/272 cams
2)Crower Valve springs
3)J&E Forged Pistons
4)Crower Rods
Is there anything I should be taking into consideration while doing these upgrades.
1999 Eclipse Spyder GST-Race
-DSM Link,Injen Intake,Spearco FMIC,HKS SSQ B.O.V.,Apex TurboTimer,Greddy Evo Exh 3",660 injectors,Walbro 255 fuel pump,B&M Fuel Pressure Reg,Heads Ported & Polished,Momo Short Shifter Clutch Masters lightened Flywheel,C.M.Kevlar Clutch,Quaife LSD,Autometer Boost & A/F Gauge, EvoIII B16g Turbo,HKS 272/272 cams & HKS Cam Gears,Crower Valve Springs & Rods,Power Pulley Kit,100 shot Zex Nitrous
Old 12-21-2004, 05:47 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Wish Me Luck Guys.
its good to replace all your fluids and replace all the gaskets , and studs ..just to be safe....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-21-2004, 06:39 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
when you do your upgraded valve springs replace the valve stem seals too. they go bad on 4g63 motors, and then your car smokes after your leave it sit a day or two.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-21-2004, 10:40 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ARP Head Studs should definitly be on your list.
Old 12-21-2004, 11:24 PM
2of9 2of9 is offline
when doin these kinds of mods...would you raise or lower your engine's C/R??
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-22-2004, 01:39 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Have you ever built a 4 cyl before? Had it apart and put it back together? You got a hell of a project ahead of you if you havent... I would definately find someone to help you. Also, I strongly suggest you sell the JE pistons unless you know people that run them in DSMs. They have been known to expand when hot and shrink smaller than the stock bore so you get major blow by until your car just doesnt run because there is no compression!
Old 12-22-2004, 08:27 AM
Sorry I forgot to mention that I did already purchase the ARP Head studs.
I am going to order the gaskets today.
And I do know 2 people that have the JE pistons in their cars. I was referred them by 2 guys in the South Jersey DSM Club. But I have never personally used them. Which ones would you recommend Jake? I dont want to harm my engine in any way. Shes only got 29K(original engine) on her and I want to get alot more use out of her. It doesnt matter much if I can't begin this project right away I can wait to get new stuff. Im going to be driving my 95 rs around for alittle while my GST sits in my parents garage till I finish it.
I do have some experience taking apart a 4cyl and putting it back together. But I will be getting some help from my fiances step dad. He's a very experienced mechanic.
Oh and one other question, with the mods I have now and the internals Im getting ready to install.....How much boost do you think I will be able to safely run?
Thanks for the help guys
