Old 12-21-2004, 07:18 AM
Future303 Future303 is offline
Damn!! Dry starts!!! Help!!
Well, this week we got majorly hit by extreme cold. It went down from like 35 degrees F to -29 degrees F within one freakin' day!!
I had to start the car like 3 times that day and I could feel it was running dry for like 1 minute before the oil started pumping thru.
Hell, I got an Oil change yesterday (went from 10w30 to 5w30) and I put the best Oil Filter I could find (K&N Oil Filter, it's supposed to have a drain back plug or something like it)
Is there anything else I can do to minimize dry starts? Thanks for the info guys.
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 12-21-2004, 09:10 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Damn!! Dry starts!!! Help!!
What are you running for oil? Cold weather does suck!
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-21-2004, 09:32 AM
Dude, I was running Mobil 1 Synthetic 10w30 for the whole summer and fall. I just got it switched to Mobil 1 Syn 5w30. I always use Mobil 1 in my car.
Old 12-21-2004, 09:33 AM
Also I think the car was running extremely rich yesterday, because I used up 1/3 more gas than I usually do for my typical day usage.
Old 12-22-2004, 09:40 AM
Guys, what I'm really worried about is how much damage I'd be causing the engine internals (Piston Rings/ Cam Bearings) by having to dry start it (maybe 30 seconds before the oil can start flowing), since I will have to use my car every day for this upcoming winter.
It looks like we're going to get some serious frikkin' cold coming our way (easily around the -30 Degree Farenheit mark)
PLEASE HELP! I've done all that I can so far, is there anything else I can do? Thank you!
Old 12-22-2004, 11:58 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
get an oil pan heater! Its like a mini heated blanket for your oil pan. I think they're magnetic. Just plug it in, crawl under your car and slap it on. Let it sit for a while, and it should start up easier. Get an oil pressure gauge too.
I searched for the oil pan heater, I got a few things... This is a stick-on moroso one for $66... I couldn't find a part # for it and couldn't find it on Moroso's site, just this dieselmann place:
http://www.intellidog.com/dieselmann/catalog.htm
On Moroso's site I did find one that screws into a 1" NPT fitting in an oil pan(actually meant for an external dry sump resevoir, but I don't see why it wouldn't work in a normal oil pan).
Go here:
http://store.summitracing.com/defaul...ch%2Easp&N=100
select 'moroso' for manufacturer, and 23990 for manuf. part #. $62. It includes a 1" steel bung to weld into your pan. If you have an aluminum pan, get this one:
http://store.summitracing.com/partde...ber&Ntt=23980+
Old 12-22-2004, 11:17 PM
^^Dude, thanks for the info.
I actually already have a Block Heater, but I can only use it at home, because there's no AC Plugs at work
Anyway, looks like the new K&N Oil Filter's drainback plug really does help, becuase I've noticed the difference.
Old 03-23-2006, 08:41 PM
MikeCTM2 MikeCTM2 is offline
Summit has the Moroso oil pan heater for only $44. part no. mor-23996 if i remember right. In the description it says it has both a 36 then 8 inch cord -Which is it? Can someone who has this let me know?
