Check engine light / slow car
I have a 91 Turbo MR2 and for some reason my Check engine light comes on whenever I start driving and my car feels really slugish. Im sure its not hitting fuel cut, because I have the HKS FCD installed and have been boosting 12psi for months with the blitz boost controller.
Im going to try the diagnostic check that I read in another post and see what code it gives me, but does anyone have any ideas what may be causing this because I have to wait till tomorow until I can check. Another thing I noticed is that my HKS instake sounds like its sucking in WAY more air when the light is on, and my boost controller shows that I am reaching 12psi faster than usual but my car is actually driving much slower than usual. Mods include: HKS FCD HKS Intake Apexi S-AFC Blitz Boost Controller All was tuned and running great for a couple months, until now.
My 91 Mr2 Turbo 245rwhp@18psi |
Re: Check engine light / slow car
My guess is going to be that you are going to get Code 52 for the knock sensor.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment |
Good guess, Code 52 was it, I had 3 codes stored but reset my ECU, drove around for a while and re-jumped the diagnosis, and got code 52 only.
So whats the next step, replace the knock sensor?
Yeppers ... the sensor should be just over $100 from Toyota. It is simple to replace.
It just has one electrical connection going into it and it is held onto the block with one huge 27 mmm nut. It's less than a 10 minute job to swap it. The concern you should have is WHY did you blow the knock sensor? ... how old are your ignition pieces? What type of fuel do you use?
I believe the ignition peices are as old as the car, as for the fuel, I use 91 chevron (premium) I live in CA so its the best I can afford.
Im boosting 12-14psi so Im thinking that may be one of the problems.
I would suggest replacing your ignition components ASAP ... I promise you will get instant power back. I am sure your power is down.
I replace my cap, rotor and wires once a year and I change my plugs every 3000 miles. Of course, you need to get a new knock sensor as well. If the best you can get is 91 octane, I would highly recommend you look into getting a water injection system. I use the aquamist system and I only use 94 octane gas on the street (110 octane when racing).
I ordered the knock sensor, I Im about to order the cap, rotor, wires, and plugs, but I just wanted to check and see if there were any wires that you suggest.
Also is about $40 correct for the cap/rotor together? I think Im going to go with the NGK 6097 to replace what Im using now.
Use TOYOTA wires.
$40 sounds right for the cap & rotor. Wires are probably around $70. NGK 6097s area great choice.
cool thanks a lot for the help, I ordered toyota wires, caps, and rotors, and the NGK 6097 for about $90 total. Plus the knock sensor for apox $100.
You mentioned water injection, I dont really know much about it, is there a company that sells it, or can I drive down to my local shop and have them order it and install it, if its not an easy install?
If you want some info on water injection, this is a good place to start reading:
http://www.aquamist.co.uk
ok I installed the cap rotor and wires, but I ran into a problem with my wires.
The #1 wire (longest one) isnt quite long enough, but the wires I bought came with something extra that I attached to the #1 wire which seemed to extend it, making it long enough. Not sure if that makes sense, but I hope theres nothing wrong with that. I assume that if that setup is incorrect the car wouldnt start?
Did you buy TOYOTA wires? It doesn't sound like it.
Toyota wires are the only ones you want in there. There is no way they should not have reached. I would not trust some sort of "extension" piece.
Re: Re: Check engine light / slow car
Look at my engine bay photos on my site ... those are Toyota wires. They are red and would have the date of manufacture painted on them in white.
If you did not buy them from a Toyota dealer ... chances are they are not Toyota wires.
OK!!!! All work is done, I went to the toyota dealership to pickup the oem wires, and knock sensor, installed them along with the cap and rotor and plugs.
Car is running perfectly now, any advice on how to troubleshoot what caused the knock sensor to go bad, so I can prevent it from hapening again?
