Old 12-21-2004, 12:25 AM
tweetybirdy tweetybirdy is offline
92 blazer keeps frying coil...help
Hello, my friend has a 92 vortec blazer. The problem is that his ignition coils keep frying out. It has gone through 2 coils in about 2 weeks. The blazer has died both times after being driven for just a few minutes. Then the coil slowy starts to melt and eventuallly gets hot enough to smell, smoke, and melt. I can't find any noticeable shorts anywhere and all the fuses seem to be fine. Hopefully you all can get me started in the right direction. Thank - Carl
Old 12-21-2004, 12:39 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 92 blazer keeps frying coil...help
What have you checked out?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-21-2004, 12:27 PM
Basically i have only checked the coil harness and the coil mount. And of course the fuses, but i couldn't find anything wrong with any of those.
Old 12-21-2004, 03:41 PM
BlazerLT's Avatar
AF -Advisor
Check it at night and look for blue spark arcing.
Needs to be dead black out to see it.
Old 12-21-2004, 08:06 PM
ya i checked it at night. There is no arcing....basically the coil is just overheating and burning up. Basically i am trying to figure out if this is a common blazer problem. I am thinking it is more of a short somewhere but i don't know where it could be or what would allow it to run for sometime and then finally fry out.
Old 12-21-2004, 08:12 PM
BlazerLT's Avatar
AF -Advisor
I would check the wiring harness and the coil to distributor wire going to the coil for shorts.
Old 12-22-2004, 10:15 AM
Fireplug Fireplug is offline
The first thing I would check is how many volts to you have going to the coil?? in the 12-14 volt range. If not check alternator out put that its not to high
Also check the grounds. High ground resistense will overheat a coil
