Old 12-20-2004, 11:39 PM
nlghtcrawler nlghtcrawler is offline
Send a message via AIM to nlghtcrawler Send a message via MSN to nlghtcrawler Send a message via Yahoo to nlghtcrawler
code #33
ok this is BS i drive a 1991 Camaro RS V6
and im getting code 33, i replaced the M.A.P. Sensor, and the ESC Module, and its still getting code #33, could it be my computer
Old 12-20-2004, 11:52 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: code #33
engine misfire or unstable idle will sometimes throw a code 33
I dont think its ECM related.. it very rarely is
Check the wiring from the ECM to the MAP, also check the sensor vacuum lines for plugs or leaks..
1991 Camaro Z28
Old 12-21-2004, 12:00 AM
Re: code #33
could it be very bad timing? cuz my teacher changed the timing on her and since then she's been acting weird. should i have him redo the timing, after i replaced the ESC? cuz he messed with the timeing before i replaced the ESC.
Old 12-21-2004, 12:04 AM
DaMoNe6969's Avatar
Re: code #33
it is definatly a possibility.. How does the car run? any symptoms?
1991 Camaro Z28
Old 12-21-2004, 12:11 AM
Re: code #33
right now, the RPM's bounce a SHIT LOAD omg i'll be going 30 and i'll let go of the gas, it'll drop to 1g, then to 500. then sometimes i'll die.
it is starting to die a lot now when i go to stop signs or stop lights.
umm, i can floor it and it dont have ANY acceleration at all, i mean i feel like a old granny out there. i fixed most, if not all, of the vacuum leaks. she idles really really rough. thats it i think, probly more but im sleepy.
Old 12-21-2004, 12:19 AM
DaMoNe6969's Avatar
Re: code #33
usually when a code 33 is present, the ECM will go into "limp home" mode.. it'l retard the timing to 22 degrees to prevent engine damage..
1991 Camaro Z28
Old 12-22-2004, 12:40 AM
Re: code #33
please someone im depending on you guys!
i really need this problem fixed!
any/all help would be appreciated.
Old 12-22-2004, 02:48 PM
DaMoNe6969's Avatar
Re: code #33
well did you check your timing?
1991 Camaro Z28
