v6 s15 no spark
1987 s-15 have replaced all major componants related to fuel delivery. problem is elec in nature . cannot get spark to plugs . have replaced coil , dist. , checked fuse links , replaced all fuses in box . problem started when i replaced water pump . after repair was made I tried to start engine and the starter wouldn't disengage so I replaced it . truck kicks but won't start ( no spark ) . cannot find voltage in wires leading into top of coil .I NEED HELP !!!
Re: v6 s15 no spark
first! double check your wires to make sure you didnt leave anything unplug or loose when you replaced the water pump. check your ignition module. your coil should have a 12v wire going to the primary side of the coil (i think on an hei system it is the big red wire). check it and make sure you are receiving 12v with the ignition on (not running).
Re: Re: v6 s15 no spark
Re: v6 s15 no spark
It has been awhile but when you changed your starter, there should have one or two fusible links attached at the hot from the battery. Did you reconnect them? Are they good? Are there any other circuits dead?
Re: v6 s15 no spark
Did you replace the rotor? I see you replaced something in the dist are but I wanted to know exactly what.
Also, have you checked your fuel pressure? Does the truck try to start if you spray stating fluid right into the TB? Did you check the timing with the timing wire removed from the PCM?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: v6 s15 no spark
you say your starter kept turning even with the key off and out of the ignition? if that is the case, i would start looking at the ignition switch. its the only thing i can think of that would be sending poewr to the coil. i am assuming since it is an 1987 truck it doesnt have an factory alarm system. does it have a aftermarket alarm system?
Re: v6 s15 no spark
You sure you aren't getting any spark?
If it kicks then you are getting some spark. Sounds like it is severly out of time. Use a timing gun and time the engine with the timing wire disonnected from the PCM. Check for spark in the plugs wires by inserting a screwdriver into the plug wire end and see if spark will arc to a brace or a piece of metal on the engine.
Re: Re: Re: v6 s15 no spark
Re: Re: Re: Re: v6 s15 no spark
Re: v6 s15 no spark
Yes, you would see some spark. Check the coil wireing for improper connections and reseat the wire going from the coil to the distributor cap.
